Sponsored by: CARiD
Power steering fluid replacement?
Old May 26, 2014 | 06:05 PM
c east's Avatar
1988 4X4 pickup...22RE
How to know when to do it and how to do it ? Charlie
Old May 26, 2014 | 06:09 PM
MudHippy's Avatar
Smells burnt? Replace it.
How? RTFM.
Old May 26, 2014 | 11:38 PM
chefdave's Avatar
When you replace fluid use atf not power steering fluid. as my powersteering cap says atf only.
Old May 27, 2014 | 09:22 AM
ZUK's Avatar
ZUK
Here's my idea which I was planning to do to my 01 Tacoma in the near future. Be adviced ....the fluid flows thru the reservoir at a fairly fast rate so have one or 2 quarts of ATF on standbye. Also, it probably is a 2 person job.
place jack stands under both front wheels such that they are off the ground and steering is extra easy to turn from lock to lock.
Dis-connect return hose and and add an extension to a 1 gallon drain bucket or larger. Have a powerful little flashlight that you can watch the fluid level easily. Have friend start engine and watch the old blackish fluid go down quickly and it will start sucking air. No biggie when it does. The point is the old fluid is out of the reservoir and now you can immediately add clean ATF as quickly as possible. Have the other person move the wheel back and forth from lock to lock and try to keep up with the increased demand. I figure in about 2 quarts you will have all good fluid in the entire system....including all thru the entire steering box because of the lock to lock steering wheel motion.
The lower the idle the better your chances of keeping up with the ATF flow rate....try to lower your idle beforehand.
Oh Ya....do not use power steering fluid in your power steering reservoir.....it will result in the seals leaking. Right on the cap it says USE ATF.
Old May 28, 2014 | 06:12 PM
c east's Avatar
Wow...I do not even know what a return hose bis....I have the toyota 1988 repair manual but have never opened it...time to study..,.Thanks Charlie
Old May 28, 2014 | 08:58 PM
rokblok's Avatar
Who is Charlie?
Old May 29, 2014 | 02:07 AM
c east's Avatar
Charlie = Me
Thanks Guys........Charlie
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
