Sponsored by: CARiD
TPS screw thread size and length?
Old May 5, 2014 | 07:03 PM
thefishguy77's Avatar
Ok started today to instal my new flame thrower injectors on my 93 22re. I am currently cleaning my plenum, intake, and throttle body as they were full of nastiness. Ok here's the question. I have had a code 41 TPS for a while. Well the bottom screw was actually missing. So the tps is loose ish. I don't want to pull the top screw out as I'm sure it's holding the tps in under tension. Does anyone know the thread pitch, size, and length of the screw.
Thanks in advance.
Old May 5, 2014 | 10:11 PM
ksti's Avatar
This link has length and pitch size and a lot of useful information on TPS
www.4crawler.com/4x4/CheapTricks/TPS/
Old May 6, 2014 | 08:02 AM
Thanks for the link
Old May 6, 2014 | 01:35 PM
Ok new question. I have tried to do the continuity test and I have no ohm registering on my current tps. I have a spare motor out of a 89 that has a factory tps. Is there a difference between the 2?
Old May 7, 2014 | 12:27 PM
ksti's Avatar
If they both are denso's check the part #'s on the back to see if they match.
Old May 7, 2014 | 12:42 PM
Unfortunately mine on the 93 is not oem but the one on my 89 spare motor is denso. So I should pull it and get the part number. Might get lucky. I did the ohm resistance test and mine tested bad. Only got 1 out of 4 tests that was remotely close to spec. Looks like its time to buy a new one. Wonder if rock auto still has them for a good price. I am definitely going to source a denso one for sure.
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
TDonkey
Jul 26, 2015 10:14 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
CanRunner
Jul 20, 2015 01:29 PM
