Sponsored by: CARiD
Rim and tire fit question
Old Sep 9, 2014 | 02:52 PM
1990toy4x4x4's Avatar
Hello.
I have a 1990 toy 4x4 pick up long bed v6 which came stock with 15 inch rims and 29 inch tires...
I have a friend who has 17 inch rims and 31 inch tires which was on his 2011 tacoma with 3 inch lift...
Would his rims and tires fit on my 1990 toy? And if so is it going o damage the truck in any way???
Thanks in advance.
Old Sep 10, 2014 | 06:57 AM
highonpottery's Avatar
Pretty sure you have a standard 6ft bed if it's a 4x4. Only 2wd had longbed option. If it's 4wd then you have 6-lug axles, in which case all toyota 6-lugs are the same pattern and will fit. You cannot however put 15" on newer truck due to brakes clearance. 31" tires were a dealer option for the 3rd gen pickup platform - so you shouldn't have any fitment issues. You will notice a change in speedo/odometer due to the new size and you'll have to recalculate unless you change gears too. There will be a slight loss in power too, and likely a slight mpg loss - but possible to gain mpg if you do lots of flat highway driving due to lower RPMs at same speed
Google image search toyota pickup with 17s (or tacoma/fj cruiser wheels) and you should find some pics.
Old Sep 10, 2014 | 07:02 AM
dropzone's Avatar
Fossilized
Do a test fit with your friends rims. You could run into clearance problems up front with the caliper. 5 minute check..
Jun 1, 2021 01:51 PM
chukarhunt
Dec 8, 2019 11:39 AM
Yotoder865
Jul 9, 2015 07:51 PM
