Sponsored by: CARiD
Head Gasket Replacement Walkthrough - '95 4runner
Old May 13, 2014 | 08:48 PM
rwbarclift's Avatar
I've got a 95 with the 3vze engine that needs its headgaskets replaced. They haven't blown, but are leaking like crazy with anti-freeze and oil coming out. I have very little mechanical experience and thought this would be a great opportunity to learn, but I've quickly found it to be pretty tough. Everywhere I see the process being discussed seems to skip over too much information for me. I hope to create a photo walk through which will cover much more of the process.
I'm working off a Chilton repair manual
My first question - directions say to "unbolt the power steering pump and position it out of the way with hoses still attached." Attached are two photos showing the 3 bolts around the the whole PS pump that I couldn't get undone. I think that the on circled in blue needs to be taken off, but the 2 reds don't, am I correct on that? If so do I need to take the pulley off and use something bigger than a hand wrench to get that off?
Attached Thumbnails Head Gasket Replacement Walkthrough - '95 4runner-powersteeringpump_ds_comp.jpg   Head Gasket Replacement Walkthrough - '95 4runner-powersteeringpump_ps_comp.jpg
Old May 14, 2014 | 06:49 AM
Terrys87's Avatar
Here is a thread that can help you with what you are going to get into.https://www.yotatech.com/forums/f199...l#post51507230 It helps when you can see what all is involved and he adds information that may be helpful when the time comes.
zd92655
Mar 6, 2022 12:58 PM
naward1996
Apr 23, 2018 05:23 PM
voiddweller
19
May 2, 2016 09:10 PM
paxanders
Jun 21, 2015 06:29 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
