Sponsored by: CARiD
Exhaust manifold gasket leak
Old Jun 28, 2014 | 08:18 PM
Daddyota's Avatar
Hey guys, I've got leaks from the manifold gasket down to the tailpipe... Normally I deal with it by turning up the radio and keeping the windows rolled up
... But I just took the top off today to do a diy bikini and realize that I need to fix it if I want my children to be birth defect free with the amount of fumes being poured out.
I'm planning on adding a new free flow exhaust and was wondering if I could reuse my old exhaust manifold and just slap a new gasket in there. I know getting headers would be ideal but they are out of my price range for now.
A friend of mine said the manifold is probably warped and that I would need a new manifold/headers anyway. Blowin smoke? I trust you yotatech, lead me in your ways.
Old Jun 29, 2014 | 12:35 AM
wyoming9's Avatar
Red face
One of those things you won`t know till the manifold comes off and you check.
Long ago I have doubled up gaskets in a low budget repair as a temp fix it most often starts leaking again.
Might be nice to know on just what your wrenching on??
Old Jun 29, 2014 | 11:23 AM
Daddyota's Avatar
86 4runner 22re. Do you need special tools to see if it's warped or can you eyeball it?
Old Jun 29, 2014 | 11:35 AM
rworegon's Avatar
Eyeballing will not be sufficient. You'll need a precision straight edge and thickness gauge measuring diagonally. Your local machine shop can inspect and resurface it fairly inexpensively.
Old Jun 29, 2014 | 12:46 PM
Terrys87's Avatar
I have seen new manifolds that are reasonably priced somewhere, just dont remember where I seen them at. I am not a fan of headers as they have a ticking noise on the ones I had and tend to leak. Like mentioned before, check your local machine shop to surface it.
Old Jun 30, 2014 | 11:48 AM
Daddyota's Avatar
Well I guess I'll yank it off and take it to a shop. Rock auto has a manifold for $65. Do I need to buy new bolts for the manifold? the original ones look pretty rusted and beat.
Old Jun 30, 2014 | 01:05 PM
CobraRed's Avatar
Taking the manifold off on these things is cake compared to most platforms.
Old Jun 30, 2014 | 01:44 PM
Nervo19's Avatar
I think that's the Dorman manifold that is made to OEM specs. It looks identical. I was looking at it recently. I also have an exhaust leak. Can anyone comment whether these are decent? I don't really want to spend the $$$ on a header.
Old Jun 30, 2014 | 01:45 PM
Terrys87's Avatar
I would replace the studs and nuts from Toyota. They sell two types of studs. One is like a 25% to 75% ration and one is a 50/50. I suggest the 50/50. They really arent to bad on prices either. The studs usually can be reused depending on condition, but buy new nuts.
Nervo19...A friend of mine does a lot of work on Toyotas on the side and I can ask him if Dormans are good. Might take a few days to see him though.
Old Jul 1, 2014 | 06:49 AM
Daddyota's Avatar
Cool thanks Terry! Im headed to the dealer anyway to get some seals/gaskets for my hubs because Im upgrading the brakes and need new rotors and have to pull all that crap out.
The dorman manifold is only 65 bucks!! Im going to try to slap a new gasket on there and see if It will fix it, but if not I may just get the dorman.
tj884Rdlx
Aug 28, 2015 12:04 PM
scottyg486
Jul 19, 2015 05:34 PM
Iceman4193
Jul 15, 2015 04:48 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
