Sponsored by: CARiD
Swamped 85 and now runs awful?
Old May 22, 2014 | 03:12 PM
SmittyMC's Avatar
I have a 1985 crawler with a 22re that I swallowed the headlights with a few weeks ago with water and drove about 150km with water in the oil. I was lucky cause there is no rod knock and I have done about 3 oil changes, changed my tps, new distributor cap, new plugs. It will start up at cold and idles very rough, no substantial backfires but the engine shakes pretty good and when I pull on the throttle cable it will even out for a second but usually it doesn't rev too high before it cuts out and actually had back pressure out my cold air intake. I have no egr and a pretty basic setup all around. What else could it be any ideas?
im thinking maf sensor?
timing?
thank you in advance!
also i ran a code 7 (tps or ecu) and that was it, even though its a new tps.
Old May 22, 2014 | 05:21 PM
jimbyjimb's Avatar
Compression test. Look inside the intake/air filter housing for oil buildup.
Old May 22, 2014 | 09:08 PM
vital22re's Avatar
totally a bro
Have you pulled the plugs? I'm gonna guess you've got a dead miss/ cylinder not firing. With the motor running, pull the plug wires off the spark plugs one at a time and see if Rpms drop. If they do, that cylinder is okay. If you find one that the rpms dont change, that's your culprit. Good luck.
Old May 23, 2014 | 12:35 PM
SmittyMC's Avatar
pulled the plugs again and the brand new plugs are all black and covered in carbon deposit but all have even distinction which leads me to believe that compression will be fine. I pulled the air filter and it was clean and dry, I stuck my finger in the afm flap and it was all dry as well. I'll do a compression test tonight once i get my hands on a gauge. this is really starting to drive me crazy.
Old May 23, 2014 | 02:11 PM
wyoming9's Avatar
Red face
The ECU`S really don`t like water if it was below the water level .
Maybe you can fine a loaner to to try and see if that fixes your issue.
Have you changed your soaked air cleaner element??? Or is the air intake and filter way above the water line
ECU is seeing way more air then your getting so the injector pulse is longer dumping to much fuel hence the black plugs
Old May 26, 2014 | 05:25 PM
SmittyMC's Avatar
ran another compression test after i had the vehicle fully boosted, they pushed 140psi each so they are good, tried starting it with my air flow meter lid off and i saw sparks. going to try maf and than computer now, thanks for the help this has been a nightmare.
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
calderp
Jul 27, 2015 09:58 AM
