Sponsored by: CARiD
95 3.0 4Runner CEL (check engine light ) suggestions?
Old Jan 7, 2014 | 12:11 PM
djcali's Avatar
Hiii im new on this forum...i have a 1995 4runner 4x4 stick 6 cylinder , have check engine light on,, i do the jump wired, and have a code 17.....look evrty wheer, and its not code 17..the light blinks ones....few seconds later blink 7 times...can any body help me whit that please!! thanks..
Old Jan 7, 2014 | 02:34 PM
rokblok's Avatar
What are the symptoms/problems?
Old Jan 7, 2014 | 02:45 PM
djcali's Avatar
has a bad idle.....but...the problem it's the need smog check and whit the check engine light on won't pass the smog..
Old Jan 7, 2014 | 03:38 PM
dropzone's Avatar
Fossilized
fixed your title to be relevant...help please isn't...
Old Jan 7, 2014 | 04:58 PM
rokblok's Avatar
Come on Robb! Maybe he was stuck at the mall parking lot...!
....I'm sure this will be deleted, but it's funny, right?!
The erratic idle could be a number of things. What's the code definition? Since I don't have a '95... Idle problem? TPS?
Upon further investigation, I gather that there is no code 17? Possibly a code 71, which I think is EGR related?
Have you tried disconnecting the battery for a few minutes to see if the CEL returns? Sometimes they will throw a hard code while running down the road, and an intermittent problem may occur... Just a thought...
Old Jan 8, 2014 | 10:20 PM
djcali's Avatar
thanks for respond, and nop. i don't have stuck at the mall...i disconect the fuse,.. light whent out for a bit and then come on again...i check the EGR lines for a like..found a small air like on 1 off the lines fixit...disconect the fuse again run's good for a day....and the light came on again....whit the same code 17.. i tought maybe 71...but give 1 solid blink and 7 short blinks
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
Dr. Evil
Jun 7, 2002 09:19 AM
