Sponsored by: CARiD
ZUK mod?
Old Mar 25, 2014 | 04:45 AM
1_\/\_YOTA's Avatar
ZUK mod?
What is the ZUK mod? Dumb question I know, but I am curious of why its called that and what is the purpose. I KNOW there are threads on this, but I am still a little confused on what and why its done. Just to fix the 4runner saggy rear ends? Thanks, Justin.
Old Mar 25, 2014 | 05:05 AM
jaretstuff's Avatar
ZUK mod is when you use a jeep TJ coil in between the frame and leaf springs. I personally would not recommend this for a truck because of the light bed vs a heavy shell on a 4runner.
I would go the block or shackle route for a much better ride.
Old Mar 25, 2014 | 06:07 AM
1_\/\_YOTA's Avatar
Ok cool. Thank you for the info!
Old Mar 25, 2014 | 07:16 AM
rattlewagon's Avatar
If your springs are worn out, a block or shackle wont help your ride, just give you height. As long as you dont get too stiff of a spring, it should pick the back up and help the ride. The ZUK mod (named for ZUK, the guy who brought it to popularity, gearinstalls.com) You can use any springs. Most use black magic springs, but 4runner, jeep tj and zj coils work too.
If you really want to fix the sag, get new springs.
There really are hundreds of threads on this.
Old Mar 25, 2014 | 07:34 AM
93Xtra-Cab's Avatar
Not necessarily. He could just find a spring that has less of a spring rate so it's not as stiff. IIRC, those who did this mod on pickups used 100lb. springs instead of the 125lb. springs recommended for 4Runners. I could be wrong. The best thing to do is contact ZUK.
Blocks
Shackles are alright, but you have to worry about changing the pinion angle. I still have a bit of vibration at various speeds after installing my shackles, so at some point, I'll have to add an alignment shim...or do it the right way and just cut the perches and rotate the axle.
With either the block or shackle, the ride quality would be the same because you still retain the same sagging spring.
Literally.
Old Mar 25, 2014 | 07:48 AM
Roark's Avatar
The best place to get the black magic springs is eBay. Check out 92 Toy's 4Runner thread for a good install of the springs.
Old Mar 25, 2014 | 08:59 AM
93Xtra-Cab's Avatar
Another thing to consider. Streetlancer used factory Celica front springs on his pickup for his No-cut ZUK Mod: https://www.yotatech.com/forums/f199.../#post51515554
Upon little research (since I'm in class right now), it seems as if the stock Celica springs are 135psi, as said in this thread: http://www.newcelica.org/forums/showthread.php?t=232289
So, they're a little stiffer, but it's another option other than black magic springs or TJ springs.
TheBFA
Feb 15, 2020 06:55 AM
punks_is_4x4
May 31, 2016 06:03 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
