Sponsored by: CARiD
81 5 speed help please
Old Feb 6, 2014 | 07:44 PM
81locked's Avatar
Ok so I'm new to the site and I need help finding out where to find the trans code on my 5 speed and what would cause my transmission to not go into gear iv replaced the clutch throw out bearing pilot bearing pressure plate master cylinder and slave cylinder and I can put the truck in gear when it's shut off and start it in 4 low and drive it around in 1st but if I start it and push the clutch in all I get is a rubber ball feeling in the shifter .... The truck will inch forward but trans won't fully engage I'm so stumped ... Sync rows maybe ?
Old Feb 7, 2014 | 06:45 AM
Lons81's Avatar
You might start looking with a shifter bushing replacement. If worn out, you will not make positive shifts
http://www.lowrangeoffroad.com/index...-and-seat.html Link isfor reference only, the part number may be different for your truck
Old Feb 7, 2014 | 07:32 AM
81locked's Avatar
Ok thank you
izzmee
Aug 17, 2015 10:20 AM
91yotapup
Aug 17, 2015 09:40 AM
129Creepin
Aug 5, 2015 10:12 PM
kyletbert
Jul 17, 2015 11:39 AM
wilbertd
Jul 6, 2015 07:39 AM
