Sponsored by: CARiD
Check engine light @ IHOP
Old Feb 3, 2014 | 04:53 PM
Streetgrinder's Avatar
I just changed the oxygen sensor on my 1988 22 RE truck. Now the check engine light comes on only when I get on the highway, after about a mile just as I pass IHOP at about 60 MPH. Is this pancake related, or maybe O2 sensor related? The light stays on until I shut off the truck. Then I can start it right up, no light until I go fast again. Strange.
Old Feb 3, 2014 | 05:03 PM
JasonYota's Avatar
Try stoping for pancakes, couldn't hurt anything.
What code is the truck throwing?
Old Feb 3, 2014 | 05:16 PM
rworegon's Avatar
You did use a Denso sensor as a replacement? Bosch or other brands is not recommended and likely to toss a CEL.
Old Feb 3, 2014 | 05:28 PM
I'll check for a code. This is the first fuel injected rig I've had, so I'm not used to checking the computer. Pancakes seem like a good idea right now.
Old Aug 6, 2014 | 06:30 AM
OK, it took me many months to figure out how to check my check engine light, but I finally got a code 26: engine too rich, or possibly a starter injector issue (I think it's the too rich one- a problem I don't share, personally). Any thoughts, ideas or comments?
Old Aug 6, 2014 | 06:36 AM
JasonYota's Avatar
Have you tested the cold start injector?
Old Aug 6, 2014 | 07:45 AM
Not yet.
Old Aug 6, 2014 | 03:08 PM
OK I just checked it. The switch is reading like it's grounded out. No resistance, bad? at about 100 F.
Old Aug 9, 2014 | 07:32 AM
Update: I checked again with a better meter, and it looks like the switch isn't the problem. I haven't pulled the injector yet to see if it's working, but the exhaust definitely smells too rich.
Old Aug 9, 2014 | 02:35 PM
Terrys87's Avatar
I have heard of the running rich condition and wondering what is causing it. Looking forward to seeing what it could be.
Old Sep 6, 2014 | 11:58 AM
I wasn't really sure about the ohmmeter test, so I got a new cold injector temperature switch used on ebay. So far it seems better. I have to drive past IHOP to really test it out.
Old Sep 8, 2014 | 10:15 AM
andykrow's Avatar
Since it started when you changed the O2 that could be a culprit. Did you put a Denso in there or something else? I learned my lesson with Bosch years ago when I immediately got codes upon installing a new one. Denso only, plus it's cheaper!
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
