Sponsored by: CARiD
Power Steering Pump Problems
Old Jan 1, 2014 | 03:18 PM
737IP's Avatar
After 16 years and 216,000 miles I replaced my power steering pump on my 94 SR5 truck with the 3.0. In doing research for this, I learned I should be been using ATF and not PS fluid. Yes, I know now it's on the cap. It didn't seem to affect it though. With the new pump, I did my best to purge all of the PS fluid from the system and replaced with Dextron ATF. After much bleeding most of noise went away. After a short drive it is making noise again and the pump has a slight vibration. I am wondering if I did damage mixing dissimilar oils.
Old Jan 16, 2014 | 02:03 PM
RSR's Avatar
RSR
Shouldn't have caused an issue.
Sure it's the pump making the noise?
Did you get all of the air/air bubbles out?
If the pump, your replacement may have an issue...
Old Jan 16, 2014 | 03:04 PM
rokblok's Avatar
Dissimilar oils shouldn't have caused any issues, except maybe for the very slight possibility that an internal bearing failed. But that would tell me that it was a cheap rebuild in the first place. Or that the shaft/pulley mate is weak/loose.
I've run mine with ATF and P/S fluid mix for 75,000+ miles. Still fine. OE stock pump
Old Jan 26, 2014 | 06:15 PM
thisismyusername's Avatar
What kind of noise? Is it screeching? Could be your bearing on the belt tensioner or what of the belts. Can make a similar noise to a power steering pump going out.
Jun 1, 2021 01:51 PM
voiddweller
19
May 2, 2016 09:10 PM
Bamripzit
Jul 19, 2015 01:17 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
