Sponsored by: CARiD
Tires and lift
Old Feb 25, 2014 | 10:39 AM
EPICbaracuda's Avatar
Tires and lift
So I'm a newbie and this has probably been asked a million times but I'm getting new tires and wanted them to be a bit meatier and the ones I have on now are getting to be pretty low and they are already hitting the fender wall , I'm up for a lift but funds are tight right now and I need new tires but am also open to lifting but don't wanna lift and have little tires any help is much appreciated .
Old Feb 25, 2014 | 10:40 AM
It's one or the other for now but should I just lift it and then not drive it till I get bigger tires ??shes not my dd so I can manage without her for a little bit
Old Feb 26, 2014 | 07:16 AM
93Xtra-Cab's Avatar
Well...we need to know what kind of vehicle you're driving in order to make suggestions...
Old Feb 28, 2014 | 07:59 PM
Oh I'm sorry , it's a 91 4runner 3.0 stock . Has 31 toyos on it now and the wheel size is P225/75/R15
Old Mar 1, 2014 | 03:15 AM
93Xtra-Cab's Avatar
Are they stock rims or aftermarket rims? 31s shouldn't be rubbing if you have stock rims. Also, 225/75/15 is not a rim size. It's a tire size. If you read that on the door sticker, that's the factory tire size. Rims are usually measured like 16"x8". 16" being the diameter of the rim, 8" being the width, for example.
Old Mar 1, 2014 | 07:35 AM
Oh I'm sorry . Yeah I don't know much about tires at all . 31.10.50R15 is what it says and I believe they are stock rims but have no idea . I do know that they do rub on my wheel wells and it makes it kinda hard to turn because they are always hitting the walls . It is from 91 so there is a little squat and I wanted to try and fix that as well with the lift but just don't want to lift and have tiny tires and end up flipping over and don't want to get too big of tires and end up not even being able to drive at all because they would be too big ..
Old Mar 3, 2014 | 05:19 AM
91 4Runner's Avatar
First off post some pictures of the 4Runner. Ones that show the wheels and fenders would really help. If 31's are rubbing something is going on that shouldn't be.
As for lift... Read this https://www.yotatech.com/forums/f116...-thread-41616/
This should answer most if not all of your questions.
Old Mar 4, 2014 | 09:05 AM
4Crawler's Avatar
Likely aftermarket wheels with less backspacing than stock. Factory offered a 31" tire option in that time frame and 31s fit fine.
You can do some trimming inside the front wheel well to help with the rubbing:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Mar 5, 2014 | 06:39 PM
thefishguy77's Avatar
My 31x10.5x15's Toyo open country MT's rub up front on full turn both directions. They are just a big tire for there size
Edit 93 pickup excab sr5 5 speed 22re
Old Mar 6, 2014 | 09:15 AM
highonpottery's Avatar
i could see how Toyo MTs will rub when a stock size "should" fit, the side lugs are huge on those tires, I have some on my truck. like stated already, it's also possible you have aftermarket wheels on your truck - so first figure that out. also, it's possible someone touched the t-bars in the front and it's sitting too low - what is your distance between center of axle to bottom of fender lip?
Old Mar 6, 2014 | 09:28 AM
MaK92-4RnR's Avatar
I'd go with 33x10.50 km2s. no lift.
Old Mar 7, 2014 | 04:43 PM
1986YODA's Avatar
39 inch iroks! Cut everything off that rubs till there is no more rubbing
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
