Sponsored by: CARiD
Leaf springs
Old Apr 4, 2014 | 05:46 PM
Crazy_Guy97's Avatar
Leaf springs
I have notice that some people on here has leaf springs in front of their rigs. Are they good to have in front? And how hard that to do that?
Old Apr 4, 2014 | 05:53 PM
Robert m's Avatar
What...?
Old Apr 7, 2014 | 08:44 AM
cheez's Avatar
Try searching SAS.
I find that googling whatever I am looking for like this: SAS site:yotatech does wonders.
Chances are, your question has a simple answer and it has already been discussed at length here on yotatech.
Old Apr 7, 2014 | 09:17 AM
rattlewagon's Avatar
I would prefer coilovers and links, but leafs are cheap and easy.
Can you cut, measure, weld? If yes, then pretty easy.
Check this kit out, has almost everything youll need and they have instructions on how to do it. You can see what it takes then decide if you want to go that way.
Really depends on what your using the truck for.
http://www.trail-gear.com/ifs-eliminator-kit
Old Apr 7, 2014 | 09:39 AM
RustBucket's Avatar
pirate4x4.com
Old Apr 7, 2014 | 11:49 AM
cheez's Avatar
Originally Posted by RustBucket
pirate4x4.com
oh you're cruel
Old Apr 7, 2014 | 02:19 PM
RustBucket's Avatar
Actually, howstuffworks.com would be a better place to start.
Old Apr 7, 2014 | 02:38 PM
Yamiryder's Avatar
should probably also make it clear that rigs with leaf springs in the front, also have a solid front axle. SAS= solid axle swap. Most guys use an 8" front axle out of a 79-85 Toyota pickup or 4runner, makes it pretty straight forward. Guessing you have IFS if you are asking about this.
Old Apr 8, 2014 | 07:01 AM
93Xtra-Cab's Avatar
'85 and earlier have factory leaf springs and a solid front axle. 86 and newer have independent front suspension. Some people remove the independent front suspension and swap in a solid axle and leaf springs or coilovers. A 4 link suspension with coilovers is ideal, as rattlewagon said, but leaf springs are cheaper easier to set up than links. Plus, most kits out there come with leaf springs. There are no 4 link/coilover kits out there that I know of.
Are they good to have in the front? It depends on what you're using the truck for, like the kind of offroading.
Yeah, he's got an 86.
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
