Sponsored by: CARiD
LIft Kit help/advice.
Old Mar 8, 2014 | 07:21 PM
1_\/\_YOTA's Avatar
I have a 5spd extra cab 94 3.0 v6 4x4. I want to find a lift kit between 2'' and 4'' that come with all 4 shocks. The objective of my truck is to keep it clean and run maybe 32''-33'' tires. It is currently stock with 31x10.5x15s. I just want to the truck to be clean and have a small amount of lift. I want to try to avoid body lifts. Any advice or pics would be great! Thanks.
Old Mar 8, 2014 | 07:49 PM
jaretstuff's Avatar
Posted in your other thread a good explanation
Old Mar 8, 2014 | 08:10 PM
Edionne13's Avatar
Rough country lift kit 700 ish all 4 shocks as well
Old Mar 8, 2014 | 08:30 PM
jaretstuff's Avatar
One thing I love about bj spacers is that they give your front frame more ground clearance.
Old Mar 9, 2014 | 11:14 AM
93Xtra-Cab's Avatar
I used this kit on my 93: http://www.ebay.com/itm/Toyota-IFS-Pickup-4Runner-2-5-Front-Lift-Kit-4WD-/270441652053?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1993%7CMake%3AToyota&hash=item3ef7941f55&vxp=mtr
Couldn't be happier.
I've said this before in other threads and I'll say it again. The kit is only $80 and it comes with the diff drop (which I strongly recommend using), the sway bar drop (if you still want to use the sway bar), and high grade hardware (metric grade 12.9). Other places sell just the ball joint spacers for $120 +/-.
Old Mar 25, 2014 | 11:39 AM
1_\/\_YOTA's Avatar
Originally Posted by 93Xtra-Cab
I used this kit on my 93: Toyota IFS Pickup 4Runner 2 5" Front Lift Kit 4WD | eBay
What shocks did you use with the kit?
Old Mar 26, 2014 | 05:49 AM
93Xtra-Cab's Avatar
Skyjacker Hydro 7000s
Old Mar 27, 2014 | 08:26 AM
1_\/\_YOTA's Avatar
I have never installed a leveling kit or lift kit. Would I need any type of specialty tools to do a leveling kit, or just a jack, some stands and wrenches in my driveway?
Old Mar 27, 2014 | 08:58 AM
93Xtra-Cab's Avatar
Let's see if I can remember what I tools used. It's been almost two years
Jack
Jackstands
Wheel chocks (safety first)
Ratchet handle, 3/8" drive
Ratchet handle, 1/2" drive
3/8" drive 12mm socket for upper ball joint studs (I think) and definitely used to install sway bar drop brackets
3/8" drive 14mm socket to loosen and tighten top shock mount
1/2" drive 17mm (I think) socket and wrench for differential drop. Definitely used for bottom shock mount.
3/8" drive 10mm socket. I don't think I've ever worked on my truck without having to use a 10mm wrench or socket. So it had to be used somewhere in the lift installation process
3/8" drive breaker bar
1/2" drive breaker bar
1/2" drive torque wrench to torque bottom shock mounts and differential drop brackets.
3/8" drive torque wrench to torque upper ball joint studs
Pickle fork to separate ball joints from spindle (if you're installing new ball joints)
Needle nose pliers to remove cotter pin from ball joint stud (again, only if installing new ball joints)
Crowbar
Penetrating oil (PB Blaster is the best I've used so far)
Mountain Dew Voltage (Not absolutely necessary. It's just a tasty beverage to enjoy while wrenching )
The only real specialty tool is the pickle fork, but it's not needed if you're not installing new ball joints.
Hopefully someone else chimes in to confirm the sizes. Again, it's been a while.
Old Mar 27, 2014 | 09:10 AM
1_\/\_YOTA's Avatar
Jack
Jackstands
3/8" drive 10mm socket. I don't think I've ever worked on my truck without having to use a 10mm socket. So it had to be used somewhere in the lift installation process
Crowbar
Thanks! Just making sure it can be done without air compressor and using some tools and elbow grease. Should I go ahead and do the BJs since I would be doing everything else?
Old Mar 27, 2014 | 09:17 AM
93Xtra-Cab's Avatar
In this thread: https://www.yotatech.com/forums/f116...-3-0-a-279112/ you say it has 280,000 miles on it. Assuming you have the same ball joints that came from the factory in 1994, I'd say it's time to replace them
Old Mar 27, 2014 | 10:09 AM
1_\/\_YOTA's Avatar
I am not sure. I would assume that they have been replaced at some point but I will need to check them out once I get a chance to!
Sep 4, 2015 09:27 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
