Sponsored by: CARiD
22r Bogging in 3rd
Old Feb 6, 2014 | 04:34 PM
AFCGooner's Avatar
22r Bogging in 3rd
Used the search function and a lot of threads became inconclusive.
I have a 92 SAS p/u with a 22r with a weber carb.
I was having issues with fuel getting to the carb. Truck didn't want to start or once enough fuel built up, the truck wouldn't run for a long time. Tested the fuel pump, and it was the culprit. I bought a new fuel pump(electric, which what the previous owner was running), new fuel filter, hoses, etc. Slapped it all in there and the truck started perfectly. Decided to take her for a spin and started going through my gears and as soon as I hit 2500rpm in 3rd, the truck just bogs bad and wants to die out. I just threw it into neutral to coast to the side of the road. Truck runs perfect in 1st gear. Is this a carb adjustment issue? Always owned toyotas but they were always 22re's
Old Feb 6, 2014 | 07:17 PM
AFCGooner's Avatar
any feedback would be awesome
Old Feb 6, 2014 | 08:28 PM
thefishguy77's Avatar
Have you repeated the action? If its only once could have been a chunk of stuff that broke free. Probably not but you never know.
Good luck
Old Feb 6, 2014 | 11:30 PM
AFCGooner's Avatar
Good luck
Has it bogged more than once? Yeah, I did some slight adjustments, though it was dark, and was just more concerned with getting home. Was in a ghetto neighborhood lol.
I'm going to check again
Old Feb 7, 2014 | 06:33 AM
Definitely see if its repeatable repeat it 2-3 times confirm its in 3rd gear, and not all others. Also since it sounds like fuel. When was the last time the fuel filter was changed. It can be a pita but cheap easy place to start if you having fuel problems. Good luck
Old Feb 7, 2014 | 10:45 AM
AFCGooner's Avatar
It happens in 2nd but at higher rpms. 3rd happens at 2500. Haven't got to shift to fourth because, well, it bogs and wants to stall.
as my op says, I changed out my fuel pump and filter along with new hoses.
Going to adjust the carb today after reading the redline tutorial
Old Feb 7, 2014 | 12:28 PM
AFCGooner's Avatar
okay wtf
I can't find the idle speed screw. I found the mixture screw, but the other one isn't where it is supposed to be
Old Feb 7, 2014 | 12:32 PM
AFCGooner's Avatar
will take pictures soon
MadMax48
Mar 3, 2020 10:33 AM
kawazx636
Sep 29, 2015 08:22 AM
runnermedic
13
Sep 21, 2015 05:20 PM
