Sponsored by: CARiD
Fluids - Front/Rear Diff's, Transfer Case - 75W-90
Old Mar 4, 2014 | 08:25 AM
Dom2332's Avatar
Looks like I can use synthetic 75W-90 GL-5 rated fluid in both my front and rear diff's and in my 5 speed manual transmission, is this correct?
Also, how difficult is it to change the manual transmission fluid?
Looking at changing all fluids this weekend in my 4x4.
Old Mar 4, 2014 | 08:36 AM
FGZ's Avatar
FGZ
There are a lot of existing threads on this, searching "75W-90 GL-4" will get you a lot of results, including this thread: https://www.yotatech.com/forums/f116...ar-oil-266968/ which looks pretty complete.
Short answer:
Yes you CAN use GL-5 in the transmission, but most folks say GL-4 will give you much smoother shifting because it allows the synchros to work better. Redline MT90 is the most highly recommended. It's synthetic, and I don't know of any 75W-90 that comes in conventional / dino variety. Sta-lube from NAPA is close, but is 80W-90 or something like that, so it wouldn't be recommended if you ever got near freezing temps.
Old Mar 4, 2014 | 08:42 AM
Dom2332's Avatar
Thanks! GL-5 has to be used in in the diff's right? Also I can use the 75w-90 in my transfer case, is this correct as well?
Where I live its is below freezing most of the winter. It's usually mid teens at night Dec-Jan.
Old Mar 4, 2014 | 08:56 AM
scuba's Avatar
I use Mobil 1 75-90 synthetic in the diffs and transfer case. I find the transmissions in these trucks are picky and since I haven't been in a spot to be able to spring for the redline MT90, the Sta-Lube GL4 85-90 is my next choice.
During cold mornings, sometimes it is slightly harder to shift, but I remedy that by warming up the transmission as the engine is warming up. Simply put the transfer case in neutral and shift the transmission to 1st.
Here's a pictyre of what I yse in my transmission.
Old Mar 4, 2014 | 09:01 AM
4Crawler's Avatar
Yes, GL-5 in the diffs for sure, hypoid gears = GL-5 oil:
- http://www.4crawler.com/4x4/index.sh...ntheticGearOil
T-case and transmission can use either GL-4 or GL-5. As noted above, GL-4 works better in the transmission due to the synchros. T-case makes no difference.
Old Mar 4, 2014 | 09:05 AM
Dom2332's Avatar
OK Thank you guys for the info!
How do you change the manual trans. oil? I don't see where there is a tipstick/fill plug??
Old Mar 4, 2014 | 09:19 AM
scuba's Avatar
http://4runner4play.blogspot.com/201...il-change.html
Old Mar 4, 2014 | 09:56 AM
dropzone's Avatar
Fossilized
Use the link scuba provided but I remove the shift boot and fill from the top until it oozes out the fill plug..way faster...
Old Mar 4, 2014 | 11:20 AM
Dom2332's Avatar
Cool, got it, thanks again guys!
4x4-runner
Apr 18, 2017 09:08 PM
4x4-runner
Dec 27, 2016 01:58 PM
Chumlee780
Nov 13, 2015 03:18 PM
yourrealdad
Jul 29, 2015 11:08 AM
crashburnoveride
Jul 10, 2015 06:39 AM
