Sponsored by: CARiD
Source of oil leak on 98 4Runner V6 LTD
Old Mar 21, 2014 | 08:41 AM
optimist78's Avatar
Hi All,
I recently found some oil spots on the garage floor and I am trying to determine the cause of leak. The spots on the floor are towards the front end center of the vehicle. Oil sludge appears on both the side of the engine block. I am not comfortable tackling the problem myself, just want to be a little more knowledgeable before taking to the mechanic.
Thanks for any input you can provide! I have attached some pics
Attached Thumbnails Source of oil leak on 98 4Runner V6 LTD-20140320_200812.jpg   Source of oil leak on 98 4Runner V6 LTD-20140320_200847.jpg
Old Mar 21, 2014 | 08:42 AM
MaK92-4RnR's Avatar
Valve cover gaskets. they're actually really easy to replace. but if you're not comfortable with pulling the intake manifold off, then I wouldn't.
Old Mar 21, 2014 | 10:03 AM
optimist78's Avatar
Thanks Mak92!. I will youtube the procedure to see if it is something I can handle.
Does anyone else think it could be something else?
Old Mar 21, 2014 | 02:55 PM
rworegon's Avatar
x2 Valve cover gasket. And, also worn out valve cover bolt grommets, and PCV valve grommet.
Old Mar 21, 2014 | 03:27 PM
MaK92-4RnR's Avatar
http://www.autofixinfo.com/Ib4scHoWZ...-Tutorial.html
Old Mar 21, 2014 | 03:35 PM
brianvolt7's Avatar
X3 valve covers. Just did my heads on v6 3vze and oil and sludge was everywhere in the compartment. After removing the upper air intake it was clearly the valve cover gaskets + a couple of really loose screws on them contributed I'm sure.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Avenged
Jul 9, 2015 07:55 AM
HRDC0R19
Jul 5, 2015 06:43 PM
