Sponsored by: CARiD
4WD engagement issues
Old Jun 15, 2010 | 03:07 PM
ohoktimmyg's Avatar
heres the situation.
93 toyota four runner 5spd manual 6cylinder motor
add obviously. i push the stick into four wheel (h or L) doesnt matter.
front drive shaft spins. stock hubs (always locked in to my understanding).
rigged actuator with hose clamp today about 10 mins ago.
i didnt refill the gear oil yet but i tested the front and i could spin the wheels freely in 4l or 4h.
all the vacuum hoses appear to be correctly routed.
i think the front diff is blown, any other ideas? (please have a couple haha)
thanks guys
Old Jun 15, 2010 | 03:19 PM
toyota4x4907's Avatar
TOYOTA never made a four runner. Its a 4Runner.
Sounds fine.... Its called an open differential
Old Jun 15, 2010 | 03:27 PM
Tofer's Avatar
Sponsor
sounds like either your ADD isnt engaging or you're describing an open diff. depending on how i read through the lines of your post...
Old Jun 15, 2010 | 03:32 PM
dropzone's Avatar
Fossilized
tweeked your title to something a little more relevant. (somebody did a better job than my tweak )
Old Jun 15, 2010 | 03:34 PM
ohoktimmyg's Avatar
crap. four and 4 seem the same when i have alot on my mind hah. my bad!
and nah i had the front wheel off the ground and the back wheel and put it in gear.(and 4l and 4h) back wheel spun its heart out, front wheel stood still and mocked my existence.
Old Jun 15, 2010 | 03:38 PM
ohoktimmyg's Avatar
tofer- i thought i had elminated the system by locking the actuator in place with the hose clamp.
dropzone- thanks, that does make alot more sense.
Old Jun 15, 2010 | 04:00 PM
brian2sun's Avatar
If your diff was blown to the point that it won't spin under power, it would make a bunch of noise when it's forced to spin when you're rolling and then it would grenade. How does it do when you try to spin it by hand when the tranny's in neutral while in 2hi, 4hi, and 4lo?
Old Jun 15, 2010 | 06:30 PM
ohoktimmyg's Avatar
both front wheels off the ground, the wheels spin either way whether in 2h,4h, or 4l, also tried all of those again with the shifter in 1st. same result. the whole time the front driveshaft remained locked when in 4wheel.
this is my understanding of the system
tcase
driveshaft
front diff
vacuum lock actuator
hubs
so if my driveshaft spins from the tcase then both of those work. i locked the actuator, and the hubs are locked. so those work. is there another piece im not getting
is this all correct or am i wrong somewhere, im not much of a mechanic, all i know is from what ive read here.
Old Jun 17, 2010 | 08:10 AM
sotb3's Avatar
i know this will probably seem like a silly question but it never hurts to ask--did you slide the lock over to the correct side prior to checking your engagement? i'm sure you did but i didn't see where you actually checked that--
Old Jun 17, 2010 | 08:40 AM
ohoktimmyg's Avatar
I found a tutorial on this site with pictures and used that. I slid it towards the driver side wheel. Is that correct?
Old Jun 17, 2010 | 12:52 PM
NO Should be to the passengers side....
Old Jun 17, 2010 | 01:16 PM
ohoktimmyg's Avatar
Scared the crap outta me. i wish you were right! it would be such a simple fix :/
heres the link i used:
https://www.yotatech.com/forums/f116...95/index2.html
and mine looks identical. i took a photo and referenced just now.
Old Jun 17, 2010 | 01:21 PM
Hmm. you must be right. Maybe that was one of the reasons my 4wd was not working when I bought my 'runner. lol. I didnt look at pics when I bypassed mine, I just took the actuator off and figured it out.
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
Coreyr384
Jul 10, 2015 11:13 AM
