ADD to Manual hub conversion help!!
Old Dec 11, 2009 | 12:43 PM
904_runner's Avatar
Originally Posted by 4Crawler
Or you can just run a vacuum line directly from the intake to the engage fitting on the actuator.
That is what i did and i never had a problem with it.
Old Dec 11, 2009 | 09:50 PM
KODE's Avatar
i was going to swap out the tube, but the add third thats in the truck has 456 gear, and the non add third i got on the side has 411 gearing. i didnt want to mess with swapping out gearing. i just took out the actuator, moved the fork to the lock position and put a hose clamp next to it so it wont move, and then i installed the manual hubs. i tested everything today and it was working great! Much thanks to you guys!!!
Old Dec 12, 2009 | 04:27 PM
DeathCougar's Avatar
What does the tube have to do with gearing?!
The axle tube is separate from the diff itself, and can be swapped regardless of gearing. I would take that ADD stuff out and put a non-add axle in there. Its much harder to do with the splined end twisted off in the diff.
Old Dec 13, 2009 | 02:44 PM
KODE's Avatar
im sorry, i misunderstood what tube you guys were talking about. i thought you guys meant the whole third. i know what you mean now.
Old Dec 14, 2009 | 09:59 AM
  #25
khamblin's Avatar
this thread seems to have taken something small and made it really complicated.... lol
Old Dec 14, 2009 | 11:15 AM
  #26
That tends to happen with the interwebs
May I direct you to the Oil Cap thread?
Old Dec 14, 2009 | 10:30 PM
  #27
khamblin's Avatar
Oil Cap thread? that could get pretty interesting...
Old Dec 14, 2009 | 11:37 PM
  #28
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Oh yes, might I suggest, strong coffee, popcorn, and a big box of tissues. You'll laugh....you'll cry....you'll scream out loud and scare the dog! But you should read it, in it's entirety!
Old Dec 15, 2009 | 06:44 PM
  #29
khamblin's Avatar
Ok, I gotta see this... is it an actual thread?
Old Dec 15, 2009 | 08:35 PM
  #30
Prepare to have your mind BLOWN
https://www.yotatech.com/forums/f5/2...-wierd-141477/
Old Dec 15, 2009 | 11:30 PM
  #31
Consider yourself warned......
Old Dec 16, 2009 | 08:39 AM
  #32
khamblin's Avatar
haha!! that's awesome... i can't believe there's 225 pages of it...
Old Dec 20, 2009 | 11:57 PM
  #33
KODE's Avatar
can we beat that record with this post?? LOL!
Old Dec 21, 2009 | 04:09 AM
  #34
snowfighter's Avatar
http://www.4x4wire.com/toyota/tech/add/
Does it matter where you tap into the vacuum in the intake? line with tee? picture?
Old Dec 21, 2009 | 06:51 AM
  #35
jrobertson4runnner's Avatar
Hey guys, sorry in advance for the thread jack. This may sound like a dumb question, but is there a way to tell if my 91 4Runner is ADD or not? or are all 91's ADD? Once again, sorry for the thread jack, and thanks for your help.
Old Dec 21, 2009 | 07:45 AM
  #36
camo31_10.50's Avatar
yep, on the front of your front diff, theres some vacuum crap on it..mans you got ADD
if you do not have lock out hubs on the front (where you have to get out and lock the hubs for the 4wd to work) then you have ADD, theres also a tag on the front diff(atleast there is on mine) that actually says A.D.D.
Old Dec 21, 2009 | 07:56 AM
  #37
Thanks Camo, thats what i thought. If you make everything non-ADD, do you have to do anything more than lock the hubs(aside from the obvious) to use 4wd?
Old Dec 21, 2009 | 08:00 AM
  #38
nope, take the flange off of your hub, bolt on the manual hub, disable the ADD(with techniques mentioned in this thread and others..like applying vacuum straight from the intake or similar) then just turn the hubs, yank the stick back on the T-case and have some fun
might i suggest 4wd donuts in an empty parking lot after it has frozen over with 3" of ice walmart lots are the best so far because of their size lmfao
Old Dec 21, 2009 | 11:52 AM
  #39
toyota4x4907's Avatar
Just remember: ALL '90+ 4Runners came standard from the factory with ADD
Old Dec 21, 2009 | 11:39 PM
  #40
KODE's Avatar
ill post some pics of how i did my manual hub conversion and how i locked the fork in place. i just gotta upload them.
