DEATH RATTLE in my Landcruiser axle 4runner
Old 06-13-2010, 09:35 AM
91MONSTER's Avatar
I have a 1991 4runner with a 91-97 land cruiser axle, at least that is what I was told. Also 4-link front and rear suspension, skyjacker hydro7000 lift kit.
MY PROBLEM: when I drive over a bump sometimes on the road my truck will get a rattle that is so intense I have to come to a stop almost to get rid of it.
FACTS: I had a wheel bearing done and the shop said my front passenger drive shaft is smaller then it should be and isn't making contact with the differential. I'm thinking that the shaft jumps up a bit on bumps and is maybe mashing the differential. I know what shaft I need but I can't find a schematic to take the hub and or brake assembly off.
PLEASE HELP ME, I JUST BOUGHT THE TRUCK
Old 06-13-2010, 06:01 PM
Tombo4Lo's Avatar
From what ive read an seene that can b a caster angle problem. I believe its the angle (front to back)betweene the top and bottom piviot points of ut steering knuckles. This is just what I think not what i know. hope it helps a bit
Old 06-16-2010, 06:18 AM
mmml4's Avatar
Sounds like the brass bushing in the spindle is worn out allowing the outer shaft of the birfield to chatter.
Old 06-16-2010, 06:20 AM
mmml4's Avatar
Try this.
http://forum.ih8mud.com/80-series-te...build-faq.html
Old 06-18-2010, 08:03 AM
91MONSTER's Avatar
I took my rim, and hub off the truck.. when I spin the shaft is makes a clicking noise ?
Old 06-21-2010, 07:56 AM
91MONSTER's Avatar
Ok I almost have everything off, but now the passenger drive shaft in the axle is smaller on the outer side and spins freely in my hub, if both sides were the size of the bigger side it would work. Anyone know what my problem is ?
Old 06-21-2010, 09:00 AM
Fossilized
Staff
dropzone's Avatar
you need to post some pictures...are you positive it is a LC axle? it is possible you blew a birfield (front axle joint)
check out all your bushing, joints etc.
are to deterimine your problem from your descriptions...
Old 06-21-2010, 05:03 PM
91MONSTER's Avatar
Ok these pics are the front right drive shafts from what I was told is a 91-97 land cruiser axle.. the problem is the straight piece is smaller on one side. I went to toyota and thats what a 91-97 landcruiser axle looks like. Now the smaller side is suppost to fit into that ball shaft(I have no idea what that is really called) It doesn't fit, it spins. The funny part is the big side of the straight shaft fits into both the diff and the ball shaft ? I don't understand ?
Attached Thumbnails DEATH RATTLE in my Landcruiser axle 4runner-bothfrontrightdriveshafts.jpg   DEATH RATTLE in my Landcruiser axle 4runner-frontrightdriveshaft.jpg   DEATH RATTLE in my Landcruiser axle 4runner-frontrightdriveshaft1.jpg
Old 06-21-2010, 09:18 PM
Tombo4Lo's Avatar
Cant tell forshure but in the middle picture it looks like the outer spline shaf(right side of pic) looks a bit chewd up
Old 06-22-2010, 07:38 AM
91MONSTER's Avatar
the side that looks chewed is a 27 spline and the bigger side is 30..My outer is a 30 spline made by longfield, I determined that the inner needs to be the same length and needs a 30 spline on each end... Some one told me that I have a 79-85 Toy P/U front axle? (based on the length of my inner)
Old 06-22-2010, 07:53 AM
Sponsor
Tofer's Avatar
take a picture of the axle housing..
Old 06-22-2010, 11:34 AM
91MONSTER's Avatar
My front and rear axles, if there is something you want me to focus on more let me know..
Attached Thumbnails DEATH RATTLE in my Landcruiser axle 4runner-dscn1160.jpg   DEATH RATTLE in my Landcruiser axle 4runner-dscn1155.jpg
Old 06-22-2010, 11:48 AM
91MONSTER's Avatar
On top of needing to know what year and model toy front axle I have, I need a new wheel bearing Hub. When I bought the truck the guy broke a couple of bolts and then to fix it he filled them with welds. Here is a picture of the good wheel bearing hub, does anyone know what year and model it comes from ?
Attached Thumbnails DEATH RATTLE in my Landcruiser axle 4runner-wheelbearinghub2.jpg   DEATH RATTLE in my Landcruiser axle 4runner-wheelbearinghub5.jpg   DEATH RATTLE in my Landcruiser axle 4runner-wheelbearinghub6.jpg
Old 06-22-2010, 11:52 AM
91MONSTER's Avatar
Bobby from Longfield thinks its an 86+ IFS front wheel bearing hub? Does that make sense
Attached Thumbnails DEATH RATTLE in my Landcruiser axle 4runner-wheelbearinghub3.jpg   DEATH RATTLE in my Landcruiser axle 4runner-wheelbearinghub4.jpg   DEATH RATTLE in my Landcruiser axle 4runner-wheelbearinghub7.jpg
icentropy
09-16-2020 02:47 PM
jerusry
10-19-2015 05:28 PM
shar
07-09-2015 12:38 PM
ItsJustD
07-07-2015 07:49 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: DEATH RATTLE in my Landcruiser axle 4runner
