Sponsored by: CARiD
how hard is a 90 to 93 swap?
Old Jun 20, 2010 | 02:38 PM
therunner6's Avatar
I have a totalled 90' 4runner 3vze, the engine is the only good thing on it. I also have a 93' 4runner 3vze, and the engine is the only bad thing on it. Does the engine just straight swap? Or is there going to be parts cost involved? If so how much?
Thanks
Old Jun 21, 2010 | 05:50 AM
tc's Avatar
tc
Yes, should swap straight over. I have noticed when using older parts on mine that sometimes the electrical plugs are not the same, but the wire colors are identical, so you just need to splice in the correct plug.
While you have the engine out is a good time to do a clutch, belts, hoses, seals, etc if you think it might need them. Also, take the time and clean up the engine really well - much easier when the diff and everything aren't in the way.
Old Jun 21, 2010 | 07:37 AM
RMA's Avatar
RMA
you will have to swap over some parts from the 93 to the 90
distributor and wires
alternator
injectors
the bunch of sensors at the rear top of the engine .(complete aluminum housing 2x 12mm bolts)
all pretty easy stuff to swap..
Old Jun 22, 2010 | 03:58 PM
therunner6's Avatar
The 90 engine I haveisnewly rebuiltabout a month old, so its in excellent shape, ifigured id have to switch out most of the plugs, just making sure it's gunna mainly just be time consuming and not money consuming. Thanks for the help.
edoyle12
11
Mar 20, 2017 02:26 AM
Backcountry411
Jul 24, 2015 08:06 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
skoti89
Jul 8, 2015 12:05 AM
