Sponsored by: CARiD
unanswered questions
Old Jun 20, 2010 | 09:01 PM
4runner dude's Avatar
22re motor has less than 5000 miles and has recently developed a high pitch squeel when above 3000 rpm. what is this? bearing somewhere? belt?
brakes sqeek with light preasure to brake pedal, but stop when moderate preasure is applied... do they need bled? or new brakes?
have plans on changing oil and everything tommorow and looking for squeel, along with a retourqe of everything.
should i bleed the brakes too?
Old Jun 20, 2010 | 09:04 PM
4Crawler's Avatar
Squeal could be due to a worn idler pulley bearing (power steering or A/C belts). You can usually remove the belt and spin the idler pulley and see what the bearing feels like. If it is loose or feels gritty while spinning, that may be the cause.
Old Jun 20, 2010 | 09:05 PM
1981 yota's Avatar
my 81 with a 22r squeeled when i got to high rpms(no tach so not sure how many) i replaced my water pump and it went away
Old Jun 20, 2010 | 09:08 PM
well i replaced all the bearings when i redid the engine. and cleaned/greased them after every mud hole. however coulda missed some water or sand. causing bearing damage. so just free spin all the bearings?
Old Jun 20, 2010 | 09:10 PM
water pump is brand new along with the rest of the rebuilt. shouldnt have gone out after 5000 miles. and if it did, im gonna have a field day down at the place i got it. cuz i want a new one
Old Jun 20, 2010 | 09:13 PM
1981 yota's Avatar
well who knows one i have a 22r and its alot simlper than the 22RE
Old Jun 21, 2010 | 09:48 PM
well i started tearing it apart today and figured out the problem. i think...
i began by testing all the bearings by hand and all seemed smooth.
so i started spraying white lithium grease on them one by one.
turns out the squeel is coming from the fan connection, i sprayed the fan shaft area and it stoped squealing for most of the day.
but noticed when i push the clutch in and let the idle fall the fan seems to take awhile to slow down
so what could be causing this?
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
