Sponsored by: CARiD
O/D Light stays on
Old Jul 9, 2010 | 07:31 PM
4runner4life93's Avatar
Unhappy O/D Light stays on
Okay guys my overdrive light stays on.My speedometer isnt working either itused to work a little bit but now its pretty much gone.I am suffering from a loss of power im not sure if this has anything to do with it or not though.Anything helps,Thanks
Old Jul 9, 2010 | 07:32 PM
Oh yeah its a 93 4runner 3.0 4wd
Bump.
Old Jul 9, 2010 | 07:55 PM
Anyone
Old Jul 9, 2010 | 08:02 PM
krytellan's Avatar
https://www.yotatech.com/forums/f116...roblem-215095/
This is one of many threads on the matter. Do a search for speed sensor (VSS) and speedometer. The consensus seems to be the speed sensor on the transfer case.
Old Jul 9, 2010 | 08:19 PM
Okay would it be in the cluster or the transfer case becasue i figured since my speedometer dint work it would be in that
Old Jul 10, 2010 | 04:50 AM
krytellan's Avatar
I can't answer that firmly. Research the threads, there is a lot of info to glean in reading others' topics. My best impression is that if you have a speedo cable, the sensor is in the dash cluster. If you have no cable (electronic) then it's on the transfer case. Again, there is a lot of info from recent questions on this matter.
It may not impact the power but this sensor typically resolves speedometer/overdrive light/trans slipping issues.
Old Jul 11, 2010 | 05:25 PM
Do you know how you can tell is its a cable or not
Old Jul 11, 2010 | 05:30 PM
Fink's Avatar
Moved to Newbie Tech Section.
A search would be the best place to start.
Fink
Liadrin
Apr 25, 2022 02:54 PM
AkitaDog
Sep 1, 2015 08:05 AM
ViperTT
Aug 14, 2015 05:27 AM
PopsDad1
Jul 30, 2015 02:21 PM
nonstop
Jul 24, 2015 06:29 PM
