Sponsored by: CARiD
Alignment get thrown off when engaged in 4x4
Old Jun 27, 2010 | 08:17 PM
vang_22re's Avatar
I have a Toyota x-cab With Manuel hubs and when I throw it in 4x4 and drive, the tires look like this \.../
But the story is that I wAs wheeling up a steep rock and my tires didn't grab traction so I went again, but this time I gave it more gas and up it goes but also had little traction at the same time. The tires was slipping but still spending and I made it. After we were done I pull onto the road and notice my front tires was super wobbly. So I engaged it back to 2wd and the wobble was gone. Also when in 2wd the tires are straight and not like this \.../
So I do not know what can be the problem and any advice will be great. Thanks
Old Jun 29, 2010 | 08:03 AM
vang_22re's Avatar
No one had similar issues???? Or had heard of this happening before??
Old Jun 29, 2010 | 08:38 AM
mightymouse's Avatar
that's crazy never heard of that before. Start taking crap apart and find the weak link.
Old Jun 29, 2010 | 08:40 AM
dropzone's Avatar
Fossilized
moved, please don't post tech questions in the build section
Old Jun 29, 2010 | 05:42 PM
myyota's Avatar
Check your wheel bearings, if there loose or worn that could possibly cause the problem your having.
Old Jun 29, 2010 | 11:55 PM
wyoming9's Avatar
Red face
I can`t see how putting it in 4 wheel drive could alter the front axle.
You need to jack this up and see what is broke
Old Jun 30, 2010 | 07:38 AM
vang_22re's Avatar
I found the problem. The front diff is shot. I wAs checking all the bushings and what not and it all look good. Then I got to the axles and the passenger side was way wobbly. The gears on the inside is probably all grind up. Will I guess it's time to regear! hahahaha thanks all you guys for the advices.
ty1er
Aug 1, 2015 11:53 PM
tomczaksdiesel
Jul 26, 2015 10:35 PM
yourrealdad
Jul 21, 2015 11:13 AM
jgwerth
Jul 16, 2015 03:23 PM
hangtown88toy
Jul 10, 2015 02:33 PM
