Sponsored by: CARiD
85 tire size
Old Jun 15, 2010 | 11:17 AM
85gijunk4x4's Avatar
85 tire size
i dont think this is a repost.. i checked lol.
i have an 85 p/u with a sa , i was wondering whats the largest size tire i could run without rubbing, i dont have a lift and dont plan on getting one. another thing i was looking at was the super swamper tsl narrow, i guess it could help not rubbing on tight turns wich i use alot considering the trails i run on require cutting the wheel all the way so i dont scrape trees.
i was figuring the largest size tire i could run was around 33', does anyone think i should regear my diffs for such a slight change?... also i dont want to get a size to big or small considering tires are only about 800 bucks a set lol, so is anyone running large tires with stock suspension and a solid axle??
any comments are welcome as always so dont feel shy!!!!
Old Jun 15, 2010 | 11:28 AM
Fink's Avatar
You're right, this isn't a repost...it's the repost of all reposts.
This stuff is all over the board - I would try narrowing your search using the Advanced Search feature.
Try searching using specific keywords after narrowing it down to the '85 section - if you still don't have any luck let us know.
Fink
Old Jun 15, 2010 | 11:46 AM
lol i didnt mean to cuse trouble lol. i did a quick search and everything i found was just for lifted trucks running 38's and such. ill check even closer this time and ill let you know. thanks
Old Jun 15, 2010 | 12:08 PM
4Crawler's Avatar
With all stock. 31x10.50 may just barely fit. We had to install a set of 1" longer than stock front shackles on a buddy's '85 with that size tire. He did have some aftermarket rims, don't recall the size/backspacing on those. 33s will rub:
- http://www.4crawler.com/4x4/4R_suspension.shtml#Epilog
My '85 w/ 3.5" lift/33x9.50s:
Old Jun 15, 2010 | 12:11 PM
Fink's Avatar
It's no trouble - I'm just glad you knew to post it in the right section.
Do some searching and reading on Roger's site and see what you can come up with.
Fink
Old Jun 18, 2010 | 08:57 PM
heyy 4 crawler, thanks for the tips, before i joined yotatech i used to read up on your site, thats where i found about yotatech lol.
djpg2000
Nov 11, 2020 04:56 AM
jgallo1
Oct 26, 2015 06:39 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
