Sponsored by: CARiD
transmission shift linkage
Old Jun 22, 2010 | 10:07 AM
quadfmxrider's Avatar
If i put my truck in park it does not want to come out, if i leave it in Neutral and pull E brake it works fine, truck shifts out fine even under a load, i stopped to get gas it was fine then, when i got back in i had to depress the button on the shifter and work it several times to get it out of park,
I was told this was a linkage and not a big fix but i wanted advice
Old Jun 22, 2010 | 10:32 AM
brian2sun's Avatar
It might be the electric switch that tells the tranny shifter that the brake pedal is pushed down and unlocks the shifter. How about a little vehicle info?
Old Jun 22, 2010 | 10:39 AM
dropzone's Avatar
Fossilized
there is usually a small pop off by the shift lever that you can remove and than push the button down to release the shift lever
Old Jun 22, 2010 | 10:45 AM
it is an 02 v6 sport edition 4x4 with about 125k miles on it
It will come out of park you just have to work it a little. I have not been putting it in park i put it in N and pull the E brake , I live in the city so its parked on flat ground and usually has a curb in front i can put my tires against so i dont have to worry about it rolling but i want it fixed.
I didnt follow about the button I should pop off, more details pls? If i didnt give enough truck info please ask and ill fill u in
crammit442
7
Nov 29, 2017 12:30 PM
Gio8
Aug 27, 2015 12:14 PM
JAmdor3
Aug 11, 2015 10:53 AM
Tykiller1994
Aug 10, 2015 07:49 PM
Motomonty
Aug 9, 2015 05:53 PM
