Sponsored by: CARiD
Front wheel arches with 33's
Old Jun 23, 2010 | 12:43 PM
Don Logan's Avatar
Hi, i've recently fitted 2 inch balljoint spacers and a 2 inch body lift to my 2nd gen Hilux Surf ('93 Toyota 4Runner).
I'm running 33inch mud tyres. I'm wondering what other people have done to their front wheel arches in order to accomodate these tyres without any rubbing on full lock when off road?
So far, i've cut away some of the front fender and hammered the pinch welds flat on the rear of the front wheel arches. Is there anything else i should do? Anyone have any pictures?
Thanks.
Old Jun 23, 2010 | 12:46 PM
85toy's Avatar
if just cutting the fender wont allow enough room then you may have to tubb the firewall. or just use a BFH on it.
Old Jun 23, 2010 | 12:56 PM
4Crawler's Avatar
Thanks.
See below:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Fender trimming for 33x12.50 tires/8" rims, w/ 1" body lift and cranked torsion bars (~1" lift):
But with that much lift, you should not need to do much of anything unless you are running a very wide tire or a wheel with very little backspacing.
Old Jun 24, 2010 | 05:19 AM
rattlewagon's Avatar
92 truck. 35s with no lift, NO torsion bar crank. Removed 3" of fender and pounded fire wall back. gives me large wheels with a LOW cog. hardly rubs, only at full lock, and that on the powersteering/ idler arm, not the body.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
1994toyota
Jul 17, 2015 03:03 AM
skoti89
Jul 6, 2015 07:45 PM
