Sponsored by: CARiD
transfer case oil/fill plug
Old Jun 18, 2010 | 10:57 PM
yota94's Avatar
first off i noticed transfer case oil leaking from the bottom of my shifter. So i replaced that seal and then i decided that i was going to go ahead and change the transfer case oil. When i took out the transfer fill plug oil came pouring out. Now i know when you fill it up you are suppose to fill up till the fluid starts pouring back out but i am guessing that approximately at least 1 quart of oil came from the fill plug. I wonder if there was too much fluid in the t-case and was causing this to leak up top? Its a 94 pickup manual 22re
Old Jun 19, 2010 | 03:32 AM
T_F_E's Avatar
Were you parked on level ground?
Old Jun 19, 2010 | 07:40 AM
yota94's Avatar
yes, this took place in my garage....... i had a t-case seal replaced at the shop and now i wonder if they filled it too full? Or i thought i read somewhere that the transmission and t-case shared the same oil......
Old Jun 19, 2010 | 10:27 AM
phildelfino's Avatar
the auto trans and transfer share trans fluid.
Old Jun 19, 2010 | 10:53 AM
85toy's Avatar
the shop prolly filled it from the top and put too much in. this is why you should learn to replace that kind of stuff your self.
Old Jun 19, 2010 | 02:37 PM
yota94's Avatar
The seal that i had them replace was the pinion seal that comes out of the t-case. They should have filled it from the bottem instead of taking my shift lever out.... Unless they thought it would b easier....... I'm suprised by whomever filled it didnt' cause any problems. Unless the transfer case isn't like oil in a engine.......
Old Jun 19, 2010 | 02:41 PM
PismoJoe's Avatar
Huh?
They should have filled it by the filler plug, they probably did but just put to much in causing to much pressure so it pushed some oil out of your shifter seal.
Old Jun 19, 2010 | 10:45 PM
yota94's Avatar
Originally Posted by PismoJoe
Huh?
I would like to know how they got that much oil pushed in there through the filler plug, w/o it pouring back out. I mean allot came out of the filler plug when i took it off..... The only way that i can think of is that they filled it from the top and left the filler plug screwed in.....
PNWrider
Oct 30, 2015 08:14 AM
SMOD
Jul 23, 2015 10:29 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
crashburnoveride
Jul 10, 2015 06:39 AM
