Sponsored by: CARiD
how many splines- rear axle
Old Jul 3, 2010 | 06:18 AM
jason22's Avatar
i have a 88 pickup 5 speed 4x4 22re. i'm putting a spool in the rear. this is only a mud truck (never sees the road). having a problem finding out how many splines are on the rear axles 27 or 30. the axle code is G292. any help would be helpful. thanks
Old Jul 3, 2010 | 06:22 AM
xxxtreme22r's Avatar
take the axle out and count them ????? Gotta take it out anyway right.
Old Jul 3, 2010 | 06:24 AM
All pre-'95 4-cylinder 4wd mini-trucks & 4Runners use the Toyota 8" 2-pinion differential rear (except turbo models). This is known as the "4cyl diff." This diff is by far the most common diff in older Toyotas. These are 27 spline axles.
'86-95 4cyl Turbo and V6* trucks and 4runners, and ALL '96+ 4Runners use the Toyota 8" 4-pinion differential in the rear. This diff is known as the "V6/Turbo diff." These are 30 splines.
Old Jul 3, 2010 | 06:34 AM
jason22's Avatar
thank you sir
Old Jul 3, 2010 | 11:32 AM
rattlewagon's Avatar
I was under the impression that all rears were 30 spline. and the fronts were 27 spline. But i could be wrong
this is a 4cly spool that is 30 spline.
http://durasolid.com/differential-pa...0ulw-31-4.aspx
Old Jul 4, 2010 | 03:51 AM
ok after looking at this, I have conflicting answers both on 4x4 wire:
http://www.4x4wire.com/toyota/faq/parts/
http://home.4x4wire.com/erik/diffs/
Old Jul 7, 2010 | 05:50 AM
Huh. Does some one know the answer to this.
Old Jul 7, 2010 | 06:05 AM
waskillywabbit's Avatar
Pretty sure all rear axle shafts are 30 spline. I got several sets sitting out. I'll count tonight.
Old Jul 7, 2010 | 06:25 AM
scuba's Avatar
I don't see anything conflicting in those.
The spline count on the first link is referring to axles.
The second link says 27 spline pinion and does not say anything about spines for the axles. Though, directly under it, it states the V6 diffs have 30 spline axles and 27 spline pinion.
The yukon spool states "Yukon Performance 1-11/16" deck steel spool for Toyota 8.0" truck with 30 spline axles" and the description is "Toyota 8" 4 Cylinder, Full Spool, 30 Spline"
The gear code or G292 confirmed, 8", 4.10, 2 pinion open.
Here's your spool.
http://www.alljeep.com/oscommerce/pr...ucts_id=174577
You've got 30 spline axles, dude.
Old Sep 11, 2010 | 06:19 PM
drew303's Avatar
all toy diffs take 30 spline axle shafts.
only front toy shafts neck DOWN to 27 spline for the birfield but the other end of the shaft isnt necked down and is 30 spline to slip into the toy third
Old Sep 11, 2010 | 06:39 PM
SoCal's Avatar
subscribed
Old Sep 11, 2010 | 07:30 PM
MudHippy's Avatar
That's a fact jack!(pardon the pun)
Uh-huh, like he says. (not that it really matters...but my 88 has the V6, axle code G292, and has a 4-pinion 8" with 4.10 gears...axle codes can be wrong...mine should be G294)
Not quite right. Close though!
Front & Rear Solid axle = 30 spline axleshafts for all 8" rear differentials. Front 8" axleshafts are 30 spline inner(differential end), 27 spline outer(birfield end), 30 spline stud(hub end)
Front IFS axle = 27 spline stubshafts/side gear shafts for all IFS 7.5" differentials
IFS CV halfshaft = 27 spline inner shaft(at the inner tripod and outer birfield-type joints), 26 spline stud(hub end)
Just went out to the shed to count the splines on my spares, got both kinds 7.5" IFS & 8" rears. Triple-checked and CONFIRMED!
Old Sep 12, 2010 | 03:36 AM
thanks MudHippy for clearing that up. I am usually good with finding info, but sometimes I read it wrong.
Old Nov 4, 2010 | 11:58 PM
drew303's Avatar
Nice clarification Mudhippy. IFS has been erased from my memory; did a hardwipe reset to 000's to try and rid my brain of IFS intel... it was corrupt and took up to much valuable brain storage space had to go after SAS hehe
:-p
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
yourrealdad
Jul 21, 2015 11:13 AM
toyoda8488
Jul 5, 2015 10:18 PM
