Sponsored by: CARiD
Towing 1,800lbs 1,200kms with 285s...
Old Jun 22, 2010 | 08:25 AM
cj_rezz's Avatar
... through the mountains. Would my truck struggle with this? I'm pulling a 1200lb trailer plus a 600lb motorcycle from Saskatoon, SK to Kelowna, BC. I've got 285s for tires with the 4.10 gears. Oh and I've bypassed the stock tranny cooler with a trucool rated for 80,000lbs.
Old Jun 22, 2010 | 08:58 AM
pwd's Avatar
pwd
What vehicle is it/motor?
Old Jun 22, 2010 | 09:26 AM
J2F42C's Avatar
I've got to see this 80,000 lb tranny cooler. Post a pic please.
If you have the 3.4L V6, I would think that there would not be a problem towing except possibly running into high winds. Tow out of O/D and go slow enough to keep the trailer under control. And check your front brake pads for wear before embarking.
Old Jun 22, 2010 | 01:59 PM
cj_rezz's Avatar
80,000lbs was a typo, I have an 18,000lb transmission cooler and the stock tranny cooler is bypassed. The vehicle is a 2002 3.4L 4Runner.
Old Jun 22, 2010 | 02:12 PM
Tofer's Avatar
Sponsor
you'll be fine... i've towed much heavier, much further with much worse motors
Old Jun 22, 2010 | 08:06 PM
wyoming9's Avatar
Red face
The most important thing to remember
Getting up the mountain is easy Going down can kill you if you are not careful!!!!
Make sure the tires and brakes are good.
Take your time and be careful you should be ok
Old Jun 22, 2010 | 11:18 PM
GabAlmighty's Avatar
I towed a little over 5K lbs on my 92 runner (3.0L).
I see you mentioned towing out of O/D, I had thought that was what the ECT power button was for, change my shifting points and didn't seems the truck was getting bogged down as much.
Just be careful when you hit the rockies, what's the general rule of thumb for how to overheat the transmission on these trucks?
Brodetski
Sep 30, 2015 11:50 PM
Cycles
Sep 29, 2015 06:37 AM
Odin
Sep 26, 2015 06:56 PM
toyhaulert100
Sep 24, 2015 07:55 PM
83
18
Sep 21, 2015 06:15 PM
