Sponsored by: CARiD
Tips: 22re oil change
Old Jun 9, 2010 | 11:45 AM
CO4runnerCorolla's Avatar
I haven't figured out a way to get the oil filter off without getting oil all over everything. Right now I'm just living with it. I was thinking about parking on a curb to jack the passenger side up, but also put the drain plug on the passenger side, so it might not drain too well. Any other ideas?
Old Jun 9, 2010 | 12:00 PM
snobdds's Avatar
Yea take off the skirt.
On a serious note, there is nothing you can do with the drain plug...it is where it is. The oil filter can be relocated with an oil filter relocater kit.
Old Jun 9, 2010 | 12:11 PM
Thanks on the relocator. I'll probably stick with the skirt till the end of summer, tho.
Old Jun 9, 2010 | 02:58 PM
snobdds's Avatar
I was just kidding you. I know I hate how the oil filter just drains all over the front diff. Poor design in my book
Old Jun 9, 2010 | 03:11 PM
Teuf's Avatar
I am not sure what the problem is. I have changed my oil going on 100 times, and never much of a mess. Stick a rag under the filter before you loosen and take it of buy hand.
Old Jun 9, 2010 | 04:30 PM
tj884Rdlx's Avatar
i thought you meant the rubber splash curtain.
actually i find the easiest way to keep it clean when pulling the filter is to pull the tire first. give me a little more room to climb in there, and i get an eyeball on the front pad thickness.
but yeah, like teuf said, a big rag under the filter right as you're about to pull it off should catch what comes out of the filter flange. tip the filter straight up as soon as it comes off the threads. that's really it man.
or if it's that much pouring out, you can try cutting the bottom of an antifreeze jug off and try to press it under there to catch spill, rather than the rag.
i say get more rags.
Old Mar 13, 2011 | 08:53 PM
acousticrawk's Avatar
i know this is old...
old bug wooden handle phillips and a hammer is all you need. punch a hole in the lower end of the filter, and catch the oil in a cut off bottle.
Old Mar 13, 2011 | 08:59 PM
874runnersr5's Avatar
thats what i do
Old Mar 13, 2011 | 09:23 PM
Teuf's Avatar
My last oil change was a bugger, filter didn't wanna budge.
Old Apr 4, 2011 | 05:52 PM
shyguy's Avatar
Originally Posted by 874runnersr5
thats what i do
Same way I do it, I make sure I wipe off as much as I can off the differential and then don't park it on a concrete driveway for a while.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
horunner1x
Jul 10, 2015 06:33 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
HRDC0R19
Jul 5, 2015 06:43 PM
