Oil filter change on 2000 3.4L
I've had my 2000 for a year now, and the first time I got the oil changed, I took it to Jiffy Lube or another place like that. Now it's time to change it again, and I'd like to do it myself. I've found out that the easiest way is through the driver's side wheel well--at least that's what some people say. So, when I lift up the flap under there, what I see doesn't look like the oil filters I'm used to. There's a round cap with a nut in the middle. I'm assuming this is the filter housing. Well anyway, I don't know what the steps are for removing that cap and replacing the filter. If you could help me out, I'd appreciate it.
http://www.4runners.org/writeups/oil/index.html
The oil filter is labeled "B"
Other maintenance can be found here: http://www.4runners.org/
Oil Cooler
That is the 5VZFE oil cooler. The engine coolant is bypassed out of the water pump and into the cooler assembly. Thats what the hoses that are attached to it are.
The oil filter is to the left more towards the front of the motor.
Okay. I see. Thanks a bunch. I'll go out there and give it another look.
