Sponsored by: CARiD
Running hot Only while driving.
Old Dec 8, 2009 | 05:03 PM
GBRAZIL's Avatar
OK im a " new " 93 4runner owner 125k. truck was running cold and could never get it to warm up ( or shift into OD ) i had to drive the thing for about 20 min before temp would get half way. so i changed thermostat only to find that previous owner took out the old one and left it open . now car heats up fine at idel , but when i drive it gets hot , what Gives. PLEASE HELP
Old Dec 8, 2009 | 06:27 PM
myyota's Avatar
Check the radiator, it could be plugged, maybe thats why the previous owner removed the thermostat because it was over heating.
Old Dec 8, 2009 | 06:33 PM
yota8083's Avatar
overheating while running down the road = radiator stoped up. I bet one tank is hot to the touch and the other isnt. This means the coolant is not circulating through the radiator causing the overheating.
Old Dec 8, 2009 | 07:50 PM
GBRAZIL's Avatar
OK. sounds simple. but is it as simple as a draining it or a complete flush
Thanks for the help guys .
Old Dec 9, 2009 | 07:57 AM
yota8083's Avatar
In this case I usually just replace the radiator. You could try flushing it first but I have found this usually doesnt fix the problem.
Old Dec 9, 2009 | 04:51 PM
GBRAZIL's Avatar
Well there you have it.. flush it and still gets hot when driving. guess its time to replace.
the1998sr5
15
Jul 14, 2020 08:35 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Poncho0206
Jul 10, 2015 06:21 PM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
