Sponsored by: CARiD
1995 4runner rear window issues
Old Dec 1, 2009 | 09:30 PM
benfryer328's Avatar
i have a 1995 4runner sr5 v6 and im having issues with the rear window. the wiper works and the window goes down but the defrost hardly works if at all and the window will not roll up. i had to press the up button hundreds of times all the while having a friend gently pull the window up until it finally engaged. it however does make a click when i press the button as if it were working properly but to no avail. what do i do? i got the window up but the defrost is still not functioning and i have not rolled the window down for a month now because it will garenteed not come back up. any suggestions?
Old Dec 1, 2009 | 09:35 PM
AK93RUNNER's Avatar
I had same issue with my 93. Took the panels off, checked & changed the motor and all is working great. 45 minute job. Piece O cake.
There are links if you look for them about this type of problem. Use the search function. It paid off for me.
Old Dec 1, 2009 | 09:37 PM
MaK92-4RnR's Avatar
heh you've made three threads now... just so you know.
Old Dec 1, 2009 | 10:15 PM
DeathCougar's Avatar
Deleted two other threads. Please do not make duplicate threads of the same topic.
btw, this topic has been covered to death and back
Use the search function. try typing in "rear window"
Old Dec 8, 2009 | 10:49 AM
aa1911's Avatar
same problem on my '93, there's a bunch of good writeups on changing the relays out with new and higher amp relays (assuming the motor is still working). Also 'lubing' up the rails is supposed to help quite a bit...
There's too many threads on this to link any single one, I've read at least 5 detailed threads on this here on Yotatech.
This is my next project after I get new spark plugs put in
voiddweller
19
May 2, 2016 09:10 PM
Corey
Jun 19, 2002 11:06 AM
95Runner
Jun 9, 2002 09:08 AM
95Runner
Jun 9, 2002 08:56 AM
