Sponsored by: CARiD
sliders before or after body lift?
Old Nov 24, 2009 | 10:30 PM
Quagland's Avatar
If i weld some sliders on and then lift the body would it end up looking wierd?
like
before lift
body
------ Slider
after lift
body
-------- slider
would something like that end up happening?
Old Nov 24, 2009 | 11:09 PM
NwRunner's Avatar
yes.
more than an inch would probably look weird in my opinion, but its all about function with sliders.
Old Nov 24, 2009 | 11:21 PM
olharleyman's Avatar
Do them after that way you can adjust your weld point on the frame to make them look like the b/l is not even on it then add gap guards to cover the see through frame area.
Old Nov 24, 2009 | 11:32 PM
drew303's Avatar
definetly after
would look BAD if you did it prior. With no body lift the sliders have to be welded at the VERY bottom of the frame.. I have a 2" BL and the sliders weld to the center (with scab plates and gussets) ..much stronger and looks way better IMO
Old Nov 25, 2009 | 09:42 PM
Quagland's Avatar
Originally Posted by drew303
definetly after
pics pls cause im gonna do a 3" BL
Old Nov 25, 2009 | 09:54 PM
stormin94's Avatar
I'd say after, since you might have problems accessing the body mount bolts with sliders welded on.
Old Nov 26, 2009 | 03:06 AM
85TurboRunner's Avatar
After would probably look the best, but if you ever decided to remove the body lift you would have to cut the sliders back off and re-weld.
Old Nov 26, 2009 | 08:13 PM
brian2sun's Avatar
No brainer IMO. 3" of gap would look horrible.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
priest16
15
Aug 6, 2015 07:43 AM
upongame619
Aug 1, 2015 12:12 AM
Cabell
Jul 24, 2015 12:14 PM
