Sponsored by: CARiD
Spare Tire
Old Dec 23, 2009 | 07:55 PM
Peterbuilt84's Avatar
Spare Tire
Does anyone know how to get the spare tire out from underneath the truck? I'm pretty sure that there is a tool that is used to lower the tire but I don't have the tool and was wondering if there is another way to get the tire out?
Any input would be appreciated.
Thanks
Old Dec 23, 2009 | 08:32 PM
lyncoo's Avatar
<-- same here lol
Old Dec 23, 2009 | 08:40 PM
rowdy235's Avatar
All you really need is something to insert in the carrier and roate it, should resemble a flat-headed screwdriver on steroids
Old Dec 23, 2009 | 09:01 PM
Etype R's Avatar
I have used a angle grinder before....
Old Dec 23, 2009 | 09:06 PM
Yeah I was considering just cutting the whole thing off because I'm not going to use it again.
Old Dec 23, 2009 | 10:42 PM
Windsor's Avatar
You use the long arm that's part of the screw bottle jack, if you have that.
Lacking that, perhaps a piece of 3/8" re-bar with the end hammered flat would do the trick.
Old Dec 23, 2009 | 10:49 PM
Yea the truck didn't come with a jack or anything when i bought it. But if a long piece of metal with a flat end will work I'll try that before I just cut the whole thing off.
Old Dec 23, 2009 | 10:59 PM
MaK92-4RnR's Avatar
speaking of the spare tire, whats the biggest tire that will fit under the truck? will a 33x12.50 fit?
Old Dec 23, 2009 | 11:09 PM
camo31_10.50's Avatar
doubt it LOL
i'm wondering if the stock swing out tire carrier for the 4runners will hold the weight of a 33x12.50?? or a 35x12.50 lol
Old Dec 23, 2009 | 11:10 PM
1GenCrawler's Avatar
right by the rear license plate should be a small round cut out. if you look through this, you should see what looks like a large flat head bolt type of thing. the tool that is supposed to be in the truck is a long bar with a loop on the end that is flat. the tool is supposed to go through the hole next to the license plate and inserted into the flat bolt and turn (not sure if clockwise or counter clockwise) this should lower the tire down from a chain to the ground. since you dont have the tool, something as simple as what everyone has mentioned would work. as for the grinder? why? dont use a grinder. the whole system should unbolt from the frame if you choose not to use it. as for the 33 tire underneath? only way to find out is to try. hope this helps.
Old Dec 23, 2009 | 11:18 PM
Brindlepitt22's Avatar
BIG PETE!
Old Dec 23, 2009 | 11:27 PM
huh?...big pete? wtf
Old Dec 24, 2009 | 12:17 AM
Thats my friend, it's a nickname
Old Dec 24, 2009 | 12:57 AM
WTF happened to the thread. Big Pete? Nevermind. some one F'd up.
Old Dec 24, 2009 | 02:47 PM
MaK92-4RnR's Avatar
Originally Posted by camo31"10.50"
doubt it LOL
I think If I moved my exhaust, I could fit the 33x12.50 spare tire under there but because its so wide, the tire might hang below my bumper... might look goofy, but im willing to try it.
but I do know that the stock swing out tire carrier can and will hold up to a 36"
Old Dec 24, 2009 | 03:03 PM
stockwell45's Avatar
if your still getting that body lift its a PIA to get the spare off. you gotta take the whole plastic strip off for the tool to be able to line up with the little winch.
just thought id throw that in there
Old Dec 24, 2009 | 03:09 PM
MaK92-4RnR's Avatar
I use a pry bar, I dont have the little tool that came with it. its not a big deal. if anything, it'll help me out a little bit.
Old Dec 24, 2009 | 03:20 PM
4Crawler's Avatar
Might try Craigslist or eBay to find the spare tire tool. I made a replacement once with a steel rod and a small dowel pin crosswise in the end. You can fit a 33 in there with relocated tail pipe or at least wrap the pipe in insulation. Tight fit, you need to pull the tire back from it's natural hanging spot and make sure it is perfectly center side-side:
33x9.50 below:
Old Dec 24, 2009 | 03:44 PM
bit.
I gotta get me one of them
Old Dec 24, 2009 | 06:48 PM
Probably gonna just try some different things, the dowel pin idea sounds pretty good thanks 4Crawler. Don't really want to buy the tool since once I get the tire out I'm probably never gonna put another one in.
