Sponsored by: CARiD
Axle to Axle length?
Old Dec 19, 2009 | 12:01 PM
MuddfreaksOffroad's Avatar
I was trying to look around online for the axle to axle lengthe between a std cab, extended cab and 4runners. I know low center of gravity is important and basically the most stable device i should say is a perfect square right? well technically the std cabs are shorter axle to axle right? so wouldnt the best for ( low center of gravity ) be a std cab?
just wondering ( doing some reasearch ) lol like a good yota owner should do right?
Old Dec 19, 2009 | 12:21 PM
4Crawler's Avatar
For side-side stability, wheel base is not a factor, only the track width and the height of the center of gravity of the vehicle. If you tip the vehicle over so that the center of gravity is outside of the wheel track, then it'll roll. Same for front-back. A longer wheel base is generally a bit more stable from rolling over backwards or forwards than a shorter wheel base.
Old Dec 19, 2009 | 06:30 PM
yes i know that but i am just wondering if a 4runner or a std cab will be better for me. ( me personally ) i kinda want a 4runner so i can bring my friends or my gf and friends along. But if the wheelbase is longer meaning the standard cab is better for overall wheeling then ill prob get a std cab. Either way i get a 4runner im not bobbing it if i get a PU i am bobbing the bed. im just doing a lil research cuzzzz ill be getting a 4x4 soon and its going to a on road off road truck but i want to be able to do some pretty narly trails without worrying bout it. lol
Old Dec 19, 2009 | 06:49 PM
4Crawler's Avatar
Same wheel base 4Runner or std cab pickup (~103"), same width of axles. 4Runner is likely a little more top heavy, especially with the top on.
Old Dec 19, 2009 | 06:55 PM
HMMMMM lol welll i guess it will allll come down to how much money i get to buy a 4x4 then? and at the time whats avalible, i want a stock, GOOD running, and fairly decent looking rig. Here in oregon its hard to find a stock sas truck thats 3000 or less. And if i get a 4runner id want a 85 that way its sfa already. I would rather not SAS any vehicle just for the fact of the cost or the build. Not that i cant do it. well thank you!
Old Dec 20, 2009 | 06:31 PM
peow130's Avatar
a "stock sas truck" wouldn't be a stock truck, lol.
if you want a stock truck with a SFA, then look at 85 or below.
you could always do a custom SAS and use the
Old Dec 20, 2009 | 11:22 PM
well technically you could say SAS = straight axle suspension .... so in a way im right hahahah but yes SFA sorry for not using proper wording!
I8URSVT
Oct 5, 2015 07:23 PM
falcon4runner
Sep 18, 2015 07:37 PM
89hilux1
Sep 14, 2015 06:13 PM
Jwp1
Sep 6, 2015 11:03 AM
