Sponsored by: CARiD
86 4 runner not starting
Old Dec 10, 2009 | 11:44 AM
ihfarms's Avatar
I have a good running 4runner at least till yesterday. Weather is very cold. It has been taking longer to crank over to start. Now today wont start. Has had tune up ignition wise. Will fire off with starter fliud. Just a pop. Any help would be great. I am a tech just not for these trucks.
Old Dec 10, 2009 | 12:59 PM
luvmy1stgenrunner's Avatar
I have '87 and have been having similar troubles. Mine has 22re motor. In normal weather conditions, it never seems to completely warm up. Now with cold weather, it starts but doesn't want to, wants to die until warms up a bit. With much research I'm looking at my cold start system. I'm just having trouble figuring out the componets of the system on my truck. How is your oil? Fuel in the oil indicates an issue of engine temperature. Can be also caused by thermo stuck open. I'll let ya know if I find out anything else.
Old Dec 10, 2009 | 01:09 PM
ihfarms's Avatar
yea mine just won't start now. Temp outside around 20f . Its been running great, but weather has been warm. Seems to be fuel issue of some sort. Just don't know alot about these. I need to get it in my shop was just wanting to drive it in not pull it.
Old Dec 10, 2009 | 01:26 PM
4Crawler's Avatar
Give the fuel pump test jumper a try:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Dec 10, 2009 | 03:00 PM
Zelephant's Avatar
My truck had an issue kinda like that; I kept blaming the starter. Turns out I just had a bad battery. Is your battery good?
Old Dec 11, 2009 | 04:33 AM
ihfarms's Avatar
Battery is new. It is a fuel issue for sure. Got a manual last night. Going to check to see if fuel pump is working. Possibly replace fuel filter. I was considering the cold start injector might be giving me fits. I love the truck just having some new owner blues.
Old Dec 11, 2009 | 07:43 AM
4Crawler's Avatar
That is the point of the fuel pump test jumper (link above).
Old Dec 11, 2009 | 04:21 PM
Integral's Avatar
what about the cold start injector? ignition switch have good contacts? plugs, wires? check those things and check continuity as well...never know where a bad wire is.
Old Dec 11, 2009 | 07:45 PM
myyota's Avatar
I had the same problem your having after i got my 86 4Runner, it was running good and then nothing, it wouldn`t start. we sprayed some carb cleaner in the intake and it would act like it wanted to start, but thats it. I had good fuel presure and spark but still nothing. It turned out to be a bad solenoid resister, so i swapped it out for a spare one that i had and my 4Runner started on the first try.
Team420
Jan 12, 2021 04:57 PM
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
torgeir
Jun 25, 2015 05:26 AM
JF9243176
Jun 24, 2015 04:53 AM
