Sponsored by: CARiD
Fixing hydraulic jack in engine hoist
Old Nov 29, 2009 | 09:29 AM
moskiter's Avatar
Hey,
I have an old engine hoist (shop crane) that has not been used for a long time and now the hydraulic jack does not work as it should. When I want to raise my engine and I pump the jack, it stops as soon as it starts to feel the resistance and it lowers down a bit. I checked the oil in it, there was just a little of it inside, so I drained the oil and replaced it with hydraulic oil. I drained it through the release screw and poured new one through the seal in the middle of the jack in lying position so that I could fill it up in full. Now it is even worse than it was because it lowers down a bit even during raising it... What did I do wrong and how should it be fixed?
Old Nov 29, 2009 | 09:52 AM
peapicker's Avatar
Sounds like the jack has bit the dirt! 2 options, somehow find a rebuild kit for the jack, go to somewhere like northern tool and find a replacement jack.
Old Nov 29, 2009 | 10:28 AM
xjdubber's Avatar
sounds like you've got some air locks in it.
Old Nov 29, 2009 | 01:15 PM
moskiter's Avatar
what to do then?
Old Nov 29, 2009 | 01:50 PM
aviator's Avatar
Best thing you can do in this case is replace the cylinder they are'nt that expensive and trying to rebuild it is a pain and might not be safe for a non-professional tech. Remember your life may depend on the jack working as advertised.
Old Jan 22, 2010 | 11:46 AM
moskiter's Avatar
that was disouraging... Anyway I took it apart and... I fixed it some seal was flipped My friend told me that it happens in these cylinders...
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
Yota.Jay
Jul 23, 2015 08:08 PM
razorman8669
Jul 12, 2015 12:13 PM
ptb12
Jul 5, 2015 01:49 PM
