Sponsored by: CARiD
Newb checking in under guise of brake question
Old Nov 27, 2009 | 07:33 PM
Mountain Cop's Avatar
Hey, I picked up a '92 4runner for my wife today. I was happy with the deal- 2600 for a 144000 mi truck. It has an auto in it, which I am ok with considering it is primarily a DD for my wife and pending daughter. The PO said that the tranny was a fresh transplant out of a '95. It shifts smoother than any 2nd gen I've ever driven, so it might be true. Looks like fresh CV boots. Not much oil or fluid showing underneath. Fresh paint job, which actually looks pretty good. Everything seems to work, except a couple of switches on the driver's door cluster. Even that works fine sporadically. It just doesn't lock the passenger front door or work the left passenger window.
The brakes feel a bit squishy, but I'm thinkin' they just need to be bled. What are the symptoms for the brake booster going? (see, I knew I would find a question to ask).
Mostly, I'm just dropping in to say, "hi". I've learned a ton already. Next mission- find me a 1st gen to play with so I don't start cutting on my wife's ride
Old Nov 27, 2009 | 08:26 PM
raydouble's Avatar
FSM link for your rig here...
http://www.ncttora.com/fsm/1990-1995...5/contents.htm
Here are the checks + bleeding procedure....
http://www.ncttora.com/fsm/1990-1995...r/checkand.pdf
Usually a failing vacuum booster will have a high hard pedal due to lack of assist, hissing sound when brakes are pressed.
Old Nov 28, 2009 | 02:52 AM
92 TOY's Avatar
Welcome to YOTATECH!!!!!!
Old Dec 30, 2009 | 06:18 AM
Thanks! Got taken care of. I replaced the pads, bled the brakes and replaced a couple of leaking brake cylinders in back. Everything is nice and firm now. I appreciate the help and welcome.
MC
Old Dec 30, 2009 | 06:28 AM
waskillywabbit's Avatar
Most shops like Meineke will do a free brake inspection for you but I see you got it figured out.
Welcome to Yotatech.
bigjstang
Jun 2, 2025 03:56 PM
Eggslinger
Jun 8, 2019 03:32 PM
87turboPA
Jul 12, 2015 07:49 AM
Coreyr384
Jul 10, 2015 11:13 AM
87turboPA
Jul 9, 2015 05:58 AM
