Sponsored by: CARiD
knocking noise when turning
Old Nov 26, 2009 | 09:04 AM
hollandridgely's Avatar
so i have this noise that i can't figure out. i think it might be a wheel bearing. i only hear the noise when i crank the wheel all the way to the right and go in reverse. the noise seems to be coming from the front passenger side of the truck.
Old Nov 26, 2009 | 09:22 AM
4Crawler's Avatar
Might be the steering stops:
- http://www.4x4wire.com/toyota/mainte...ront_end/lube/
Old Nov 26, 2009 | 10:22 AM
it is strange b/c it doesn't make the noise when i crank the wheel all the way right and drive forward. just in reverse.
Old Nov 26, 2009 | 11:26 AM
4Crawler's Avatar
Well, it could be the forces are different in reverse than forward and push the stops into contact in only that combination. Takes 2 minutes to smear a little grease on the stops if they are missing the plastic caps. If that silences the noise, problem solved, if not, you have eliminated that potential cause from the problem.
Old Nov 26, 2009 | 11:41 AM
22RUCRAZY's Avatar
Do you feel it in the wheel if not it may just be the plastic shroud on the steering knuckle under the hood , it happened to me good luck
Old Nov 26, 2009 | 08:10 PM
brian2sun's Avatar
What kind of truck is it? Sounds like a bad cv to me.
Old Nov 27, 2009 | 05:55 AM
Green_slime's Avatar
ya it could be a bad cv or the hub is goin out
Old Nov 27, 2009 | 07:44 AM
i have a 91 4runner with no special editions. thanks for the advice.
Old Nov 27, 2009 | 01:39 PM
so just went for a little drive and i noticed that my noise isn't just when the wheel is cranked all the way right. the noise starts before the wheel is cranked all the way, and continues when the wheel is all the way cranked.
Old Nov 27, 2009 | 04:06 PM
22RUCRAZY's Avatar
Do you feel it in the steering wheel or can you just hear it ?
Old Nov 28, 2009 | 09:30 AM
i'm pretty sure that i just hear it. if i felt anything the where would i feel it?
ripp96
Jul 25, 2015 02:32 PM
yourrealdad
Jul 21, 2015 11:13 AM
keithporter83
Jul 18, 2015 12:37 PM
razorman8669
Jul 12, 2015 12:13 PM
smiley52
Jul 11, 2015 05:16 AM
