Sponsored by: CARiD
Changing front axles...what all is needed?
Old Nov 29, 2009 | 04:23 PM
tondog's Avatar
Like some others here I recently put a 3" lift on my 2000 runner. I also did the diff drop but my cv boots still failed. Rather than mess with new boots, I bought two new axles. Never done this before but from what ive been reading on here it doesnt seem too hard. My question is what else should I replace or change while ive got everything apart. Wheel bearings? output shaft seals? I dont really know much about suspension but I put the lift on the the front and rear with out too much pain. Hopefully this will go the same. Also, do I need to drain the diff fluid? I imagine so.
Old Dec 5, 2009 | 10:47 PM
Rix's Avatar
Rix
Not much else changes over when the axles are pulled.
If your seals are leaking or you damamge them, you'll need to change them.
If it were me, i'd buy new lower ball joints.
Old Dec 6, 2009 | 11:25 AM
tondog's Avatar
Thanks for the reply. Ive been feeling stupid because in all the searching ive been doing I havent found any info on newer axles like the 2000 runners. I havent started yet. It looks like the machined part of the axle maybe goes into a bearing on the diff and im not sure but what seals it? just an o-ring or something. or is it like a seal like a crank shaft seal? and does the black cap on the wheel end of the axle just pry off?
Old Dec 6, 2009 | 12:04 PM
VSU_4runnin's Avatar
well id say since your already replacing them, go with manual hubs i.e. convert your add to manual it will take stress off the cv's and ive heard increase your gas mpg's.
as for the diff, when was the last time the fluid was changed? i do mine about every 50-75k
Old Dec 6, 2009 | 02:26 PM
tondog's Avatar
Wink
yeah but im too lazy for that. I want to be able to just shift or push a button and be set.
BigArt70
Jun 30, 2015 09:51 PM
YotaGreenhorn
Jun 27, 2015 07:00 AM
TheManOutside
Jun 18, 2015 03:32 PM
HALMAN
Jun 14, 2002 09:02 PM
