Sponsored by: CARiD
Trail Gear sliders.
Old Dec 16, 2009 | 09:31 PM
chriso's Avatar
Trail Gear sliders.
I'm getting some Trail gear sliders for my 98 4 runner. How are you guys mounting these? The brackets that I'm getting with look like they have holes for bolts in em what kind of bolts are you guys using? Grade 8 grade 5? Metric 8.8 10.9? Also I would imagine welding the brackets would be smart as well. Any help is appreciated.
Old Dec 16, 2009 | 09:37 PM
MaK92-4RnR's Avatar
most of the people you will find on here just weld them to the frame.
Old Dec 16, 2009 | 10:22 PM
Tubbyfatty's Avatar
yea just weld em if you REALLY wheel and need them, if your goin for the mall crawlin look, just get steps.
Theres sever threads about this topic. click that search button up top.
Old Dec 16, 2009 | 10:45 PM
chriso's Avatar
My runner sees dirt more than pavement. They will be taking a beating I was just wondering if the weld would be secure enough as I thought people were bolting em down as well.
Old Dec 16, 2009 | 10:57 PM
stockwell45's Avatar
welded on the bracket
then welded on the arm
works out great, just make sure you want them on forever
and welding is way more secure than bolting, welds are even stronger than the metal
Old Dec 16, 2009 | 11:28 PM
drew303's Avatar
The holes in the brackets arent for bolts! .. Those are for rosette welds, you fill them in with weld, it makes the plates much much stronger. Then weld the bracket around the perimeter like in the post above.
I wouldnt bolt them... thats rediculous, ever drilled Metal? It's a pain and takes forever and if you dont know how to properly drill metal your going to waste bits in about 15 seconds.
Old Dec 16, 2009 | 11:42 PM
chriso's Avatar
^^^ yes I have drilled metal, I worked in a pretty big industrial farming hardware/fab shop down here in norther CA. I'm actually just starting my welding classes this semester though. I have had little experience welding but me and my pops can knock it out. Thanks guys I appreciate the help!
Old Dec 17, 2009 | 02:49 AM
4banginRunner's Avatar
bolting wouldnt be good with a boxed frame anyway...w/o sleeving the inside at least
burn um on
Old Dec 17, 2009 | 04:29 AM
Yota Runner's Avatar
also make sure you get the 60 inchers and not the 58 inch. The 60's fit nicer imo
XtraCab
Apr 12, 2020 05:25 AM
Scotto6591
Sep 1, 2015 03:24 PM
Backcountry411
Diesel Swaps
Jul 29, 2015 01:33 PM
msane99
Jul 27, 2015 06:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
