Sponsored by: CARiD
4.56 or 4.88 gears??
Old Nov 30, 2009 | 11:03 PM
traxxi2003's Avatar
Question 4.56 or 4.88 gears??
Hello there!
I need to regear my 1997 4Runner SR5 2WD Aut Trans, since I will be installing 33x12.5*15 tires. Right now with factory tires at 65mph the rpm's are at 1950, How much higher will they be with 4.88 gears? Is 4.88 too much? Or should I go with 4.56 instead? I will like to gain a little extra performnace without having my engine reving to much higher from factory setting. Any advice will be appreciated. Thanks!
Old Dec 1, 2009 | 12:01 AM
SpecialScottie's Avatar
4cyl or V6?
If you have the 4cyl Id go with the 4.88s
Old Dec 1, 2009 | 12:15 AM
91Toyota's Avatar
definitely need to know what you have under the hood!
Old Dec 1, 2009 | 12:33 AM
stormin94's Avatar
X2
Old Dec 1, 2009 | 12:52 AM
traxxi2003's Avatar
Sorry! V6 3.4L
Old Dec 1, 2009 | 01:31 AM
stormin94's Avatar
Then 4.56 should be adequate.
Old Dec 1, 2009 | 08:12 AM
crolison's Avatar
4.88's
Old Dec 1, 2009 | 10:47 AM
TRDPARTS4U's Avatar
FormerVendor
On my '98 with 255/85/16 tires at 65 mph with 4:88 gears I'm turning 2300 RPMs.
V6, auto.
Jacque
Old Dec 1, 2009 | 10:52 AM
mt_goat's Avatar
4.88s would be good with that setup, I'm geared even lower than that (5.29s).
Here's a good calculator:
http://www.ttora.com/forum/showthread.php?t=56784
Old Dec 1, 2009 | 05:19 PM
brian2sun's Avatar
I'm very glad that I did not go w/ 4.56s - would have been a lot of $$ for a marginal difference. 4.88s are the way to go w/ a 3.4 and 33s.
Old Dec 1, 2009 | 05:32 PM
82blueyota's Avatar
so i have a 82 1st gen with the 22r. would 4.88 be to much for 30" tires or would 4.56 do the job can you still do 70 with lower gears
Old Dec 1, 2009 | 05:37 PM
camo31_10.50's Avatar
well if your gonna stick with the 30" tires..or never go bigger than a 31" tire..then yea 4.56's would be good..but if ya plan on goin any bigger..get the 4.88's
Old Dec 1, 2009 | 09:47 PM
traxxi2003's Avatar
Thanks everyone for replying back. I'm definetly going with 4.88. Its only about 200-300 rpm increase from my current setup. Hopefully that will translate in a decent performance increase even after upgrading to 33's.
Old Dec 2, 2009 | 08:51 AM
ESQ's Avatar
ESQ
4.88 for manual, 5.29 for automatic (because of the 5th gear and overdrive ratio differences).
Old Dec 2, 2009 | 05:42 PM
82blueyota's Avatar
I do 70 every day to work its my dd works great at that speed
Old Feb 7, 2010 | 10:02 PM
ChildrenOfBodom's Avatar
I have a 99 2.7 2WD with 265/70/17's.
I have 3.91's stock I am pretty sure so I was gonna swap to another 4Runner diff.
My problems really are that I have no low end power and when going uphill, I can barely get up most of the time. Uphill on the way to Mt. Baldy then actually climbing the mountain was awful. When the car is loaded, flooring it couldn't keep me up with the Sienna in front of me. I would love some acceleration for those "Lane Merges Ahead" types of deals, etc.
So what would one recommend? 4.56s, 4.88s? I want to just do a straight up swap with no modification. A locker would be great but I've heard those only come with OEM 4.10 gears.. true or false? A locker would drive me to do the extra modification.
Thanks to anyone who can help
Old Feb 7, 2010 | 11:06 PM
brian2sun's Avatar
An elocked diff will require modification to your axle. The highest elocked diff you are likely to find is a 4.30. You could buy an entire 4runner axle w/ a factory elocker and 4.30s if you want to go the easier labor route and avoid the cutting and welding, but it would cost more.
4.11s would be a pretty insignificant difference, so I would go with at least 4.30s. If you decide to just change your ring and pinion only and forget the elocker, I would get 4.56s since you have the choice and they will give you a little more power/torque than the 4.30s - especially since you have a 4 banger.
Old Feb 7, 2010 | 11:12 PM
vital22re's Avatar
totally a bro
i've got 4.56 with a 3.4 and 5spd 265/75/16.. 1st gear is barely a second long. 70mph is 3000rpm. Granted its nice for towing.. but for daily driving its a pita... just my experience.
Old Feb 7, 2010 | 11:25 PM
brian2sun's Avatar
Wow that's high pretty high, I don't hit 3000 rpms until 80 mph with 4.88s, but i'm running 285s and have an auto tranny. I would think the heavier 4runner with a 2.7 would still be better with 4.56s than 4.30s, but hopefully someone on here with that set up will chime in.
Old Feb 8, 2010 | 05:31 AM
crolison's Avatar
Originally Posted by brian2sun
Wow that's high pretty high, I don't hit 3000 rpms until 80 miles per hour with 4.88s, but i'm running 285s and have an auto tranny. I would think the heavier 4runner with a 2.7 would still be better with 4.56s than 4.30s, but hopefully someone on here with that set up will chime in.
If you got a heavy 2.7l runner just go 5.29's and call it done
