Sponsored by: CARiD
transmisson name question?
Old Dec 23, 2009 | 02:41 PM
ethanp123's Avatar
i have a 1986 4runner with an automatic transmission wondering what the name of the tranny is? For instance the name of a chevy tranny is a turbo 400!
Old Dec 26, 2009 | 03:08 PM
annoyingrob's Avatar
Isn't the correct name for the Chevy a TH400? People just nickname it a "Turbo" 400?
Your transmission in your 86 should be an A340H.
Old Dec 26, 2009 | 04:06 PM
ethanp123's Avatar
i don't know i just call it turbo 400!
Old Dec 26, 2009 | 04:11 PM
1990yota-pickup's Avatar
they make a turbo 350 400 700r4 460LE most common gm trany's
Old Dec 27, 2009 | 03:21 PM
Flash319's Avatar
I believe the TH400 stands for Turbo-Hydrostatic 400, just a guess though. I think in your Yota you will have an A43D or an A340E or A340H. No cool name though . Toyota is enough!
Old Dec 27, 2009 | 03:36 PM
if your always squealing the tires off stop light from stop.. then i belive its pretty cool.. tranny just no fancy name......just keep some used tires on hand for all those burnouts
Old Dec 28, 2009 | 09:39 AM
Flash319's Avatar
Right, hydramatic. One of those names that GM came up with in the 50's or 60's. I wonder why they are doing so bad.................
Old Dec 28, 2009 | 10:21 AM
i rebuild 460LE's everyday at work... its what the put in hummers,
Old Jan 1, 2010 | 08:13 PM
The only cleverly named transmission Toyota ever had was the toyoglide.
Yes, it exists.
Old Nov 15, 2010 | 02:11 PM
Devil4me666's Avatar
what is the differnce between A340E and A340H? If I have an E what would be the issue with using an H?????
Old Nov 15, 2010 | 08:16 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
OMG, all of you are WRONG!
It's an 86! It's an f! As in, "A340f"
H stands for Hydraulic
f, four wheel drive, IIRC.
No, it is not an H case.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
