Sponsored by: CARiD
trucks runs rough
Old Dec 10, 2009 | 01:36 PM
85yota4x4's Avatar
trucks runs rough
when i am driving when i let my foot off the gas it feels like i am pressing on and off the brake, it kind of hops. what could be causing this? it runs really rough especially in first gear.
Old Dec 10, 2009 | 02:14 PM
brian2sun's Avatar
How do the u-joints look? Any play in the driveline? How does it run rough while in 1st?
Old Dec 10, 2009 | 02:17 PM
clydehatchet's Avatar
maybe the drive shaft is out of balance.
Old Dec 10, 2009 | 02:21 PM
85yota4x4's Avatar
yeah it does run rough in first. drive shaft did run across my mind but im still not sure.
Old Dec 10, 2009 | 08:57 PM
yota8083's Avatar
Is it running rough like its missing or is the idle fluctuating or what?? Is the motor running rough or is it riding rough?? We need some more details about exactly how its running in order to help.
Old Dec 10, 2009 | 09:17 PM
Teuf's Avatar
Plug wires?, Hope you fix her, your 85 is one of my fav's here.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale and the lowest morals of any group of animals I have ever seen. Thank GOD for the United States Marine Corps!" - Eleanore Roosevelt
Old Dec 10, 2009 | 09:55 PM
85yota4x4's Avatar
my idle was fluctuating really bad the other day but i replaced my mass air flow sensor and that fixed my idle problem, so now it is only riding rough. its really bad in first gear, and it only does it when its in gear
Old Dec 10, 2009 | 10:06 PM
Heichel23's Avatar
axel wrap?
Old Dec 11, 2009 | 09:41 AM
Teuf's Avatar
In first gear with a truck that makes 80 rear wheel hp? prob not
Old Dec 11, 2009 | 01:30 PM
85yota4x4's Avatar
i understand the drive shaft making the truck run rough, but would it make the idle fluctuate like it does.
Old Dec 11, 2009 | 01:46 PM
83's Avatar
83
I think you need to isolate, and be more clear what you mean by "running rough". To me that means an engine performance issue, not some sort of driveline or chassis vibration.
If this is an engine issue, then of course look at things like a general tune up, fuel delivery system, etc.
If it's a vibration when you let off the gas, look at d-shafts, pinion nuts etc.
Old Dec 13, 2009 | 04:55 PM
pilot0701's Avatar
i have a problem almost like 85yota4x4 does but mine runs rough like it is missing at highway speeds and fine at idle
Old Dec 13, 2009 | 05:05 PM
Teuf's Avatar
Pilot that sounds like plug wires, mine did that. Kind of a skip bump, very subtle, wires fixe that.
Old Dec 13, 2009 | 07:21 PM
85yota4x4's Avatar
big blues all fixed and running great
Old Dec 13, 2009 | 07:27 PM
brian2sun's Avatar
So....
What was the problem?
Old Dec 13, 2009 | 07:35 PM
85yota4x4's Avatar
the cable that goes to the air flow sensor
Old Dec 14, 2009 | 04:24 PM
pilot0701's Avatar
rough running turck
thanks Teuf for the reply, but I changed the wires, the plugs, the cap and rotor,before this started happening, and the fuel filter today to see if that would help it runs fine at idle and as soon as go to drive it, it wont rev very well and when you go to go up a hill it it has no power.I htink it might be the intake, or the crack in the exhust manuifold any other ideas would be alot of help
Old Dec 14, 2009 | 04:46 PM
Teuf's Avatar
Pilot, your Cat OK?
Old Dec 14, 2009 | 06:31 PM
85yota4x4's Avatar
thats what mine did once i unplugged my air flow sensor the idle got good but once i drove it it wouldnt rev good at all
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
puffin04
Jul 10, 2015 09:17 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
slider417
Jun 22, 2015 10:18 AM
Dr. Evil
Jun 16, 2002 07:52 AM
