Sponsored by: CARiD
weber 32/36 probems, again!
Old Dec 24, 2009 | 08:49 AM
kbond01's Avatar
ok, 22r, no smog, weber 32/36 electric choke. timing is set perfect, had a pro do it. however, the choke on the weber is staying on once the motor is up to temp, and when you disconnect the 12volts to the choke it kills the motor. other than that it runs like a top.
weber is sending replacement parts for the choke, but has anyone else seen this?
im thinking there maybe be something wrong internally, beacuse if the motor is warm, it shouldnt need any choke at all?
Pri$erulz
Nov 17, 2019 08:03 PM
user 82300
Jan 19, 2016 02:01 PM
highonpottery
Nov 22, 2015 03:57 PM
kawazx636
Sep 29, 2015 08:22 AM
