Sponsored by: CARiD
Replacing ball joints
Old Dec 15, 2009 | 04:13 PM
Cal01's Avatar
anybody here here ever done it without using special tool? hard? mines smashed up and want to fix it before replacing the tires.
Old Dec 15, 2009 | 04:28 PM
BigBluePile's Avatar
There's alot on here about this...
Mine pretty much fell out. However, a tie rod end puller is fairly cheap and works just fine poppin ball joints out.
Old Dec 15, 2009 | 06:09 PM
Zelephant's Avatar
I used a pickle fork on mine. Took quite a bit of hammering but it did come out.
Old Dec 16, 2009 | 12:01 AM
brian2sun's Avatar
Just did my lowers, pickle fork and a hammer worked fine and mine popped out easy. I used the pickle fork for the outer tie rods too. New ones just slide in and then you tighten the nuts. Upper ball joints are a little harder to do.
Old Dec 16, 2009 | 12:04 AM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Uppers or lowers? You can do the uppers without a puller. Jack up the side of the truck your working on, and put a jackstand there. Then put a jack under the A-arm, remove the shock, the 4 nuts on top, and lower the jack.....then get a BFH, and pound on the A-arm, lower the jack down some more...repeat. It took me'bout 35 min to change 1 upper.
If your doing lowers....sorry I can't help you there.
Old Dec 16, 2009 | 12:05 AM
brian2sun, you snuck your answer in there as I was re-reading mine.....LOL.
Old Dec 16, 2009 | 08:35 AM
brian2sun's Avatar
That's cuz I'm sneaky...haha.
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
ptb12
Jul 5, 2015 01:49 PM
