Sponsored by: CARiD
89 4runner no start
Old Dec 21, 2009 | 02:14 PM
mattgauvin's Avatar
89 4runner no start
just bought the truck ans kindof a project truck, went and looked at it started and ran perfect drove good, all stock just with 31's. only problem i saw with the truck was the o2 sensor was cut out of the exhaust and was hanging...idk why, but still ran fine so i wasnt worried at the time, long storry short, i gave him my price, told him to call me. that day he drove the truck and it broke down he had it towed home....called me back the next day and asked if i was still interested. me (not knowing the truck had broken down) bought the truck....so far ive found the truck not to be making a spark...so ive replace the coil and igniter, which helped nothing. car turns over freely, starter is fine. not sure if the motor is an interference or not...havent check the timing belt but dont here any metal banging noise in the motor. o and its the 3vze. any advice would be great, thanks
Old Dec 21, 2009 | 02:31 PM
1990yota-pickup's Avatar
from what i understand. its a 22re/r or a v6 3.0 well its not a interference on the v6 3.0 so u should be good. does the engine crank over faster then normal would mean that the timing belt is broken.. pull off the cover and have a look at of it... timing belt should be replaced about every 80k miles or so... aslong as u keep up the preventive maintenace on your rigg it should last a life time
Old Dec 21, 2009 | 02:37 PM
mattgauvin's Avatar
yea starting to think it has to do with the timing belt, been really cold out lately so i haven't checked, tomorrow i guess ill just bight the bullet and get it checked out would that cause a no spark situation?
Old Dec 21, 2009 | 02:40 PM
jeolllloep's Avatar
remove distributor cap crank engine see if rotor cap turns...if it doesnt turn,broken belt....
Old Dec 21, 2009 | 02:45 PM
mattgauvin's Avatar
big job to do? and annnny ideas on why the guy cut out the o2 sensor? doesn't make sense to me, but im relatively new to yotas. haha let me know
Old Dec 21, 2009 | 03:05 PM
did u get out there and pull off that distrubtor cap.. and crank the engine.. well what are you waiting for... i hope u have a heated garage to work in...
Old Dec 21, 2009 | 03:10 PM
mattgauvin's Avatar
haha, cars at my friends cause my driveways full of other non running cars, and its like 5 degrees out, but tomorrow morning ill be out there, would no o2 make it run really rich/lean? i dont get there logic in cutting it out
Old Dec 21, 2009 | 03:40 PM
the o2 sensor controls all of that.. your on the right track.. if you have a california model truck you have 2 o2 sensor before and after the catlityic convert
and there is a sensor on the intake aswell where the egr line hooks up. to the intake..
Old Dec 21, 2009 | 05:50 PM
mattgauvin's Avatar
mine only has before the cat, if it was out would it set the check engine light?
Old Dec 22, 2009 | 09:26 AM
mattgauvin's Avatar
took apart the distributor today and everything was spinning and working right, so the belt is still together, is there anyway that the computer could have fried? i took a plug out and turned over the motor a couple times, i didnt smell any fuel and the plugs were perfectly dry so im guessing im not getting fuel either
Old Dec 22, 2009 | 10:14 AM
if the o2 sensor is not hooked up.. it will constanly throw the check engine light on.. look in the manual.. goggle up "what a o2 sensor actually does"
Old Dec 22, 2009 | 11:03 AM
ScottyC's Avatar
Not on an OBDI motor. One O2 sensor under the DS door in front of the cat.
Check the EFI fuse under the dash.
Old Dec 22, 2009 | 11:20 AM
Tracey98277's Avatar
the 22 is very much an interference engine.
Old Dec 22, 2009 | 11:35 AM
did u ever check your fuel pressure?
Old Dec 22, 2009 | 12:18 PM
Lumpy's Avatar
Here is a silly question...is there fuel in the tank???
Old Dec 22, 2009 | 12:52 PM
ScottyC's Avatar
Only the pre-84 models. All 84+ 22R and 22RE's have dished pistons and a taller deck height. They are non-interference motors.
Old Dec 22, 2009 | 08:03 PM
mattgauvin's Avatar
haha yeah i have gas in the tank, that was my first try at fixing the problem haha, ill check the efi fuse tomorrow i guess, has anybody ever fried there computer? or is it possible i have a bad air flow meter? would that kill spark?
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
torgeir
Jun 25, 2015 05:26 AM
JF9243176
Jun 24, 2015 04:53 AM
JaredL
Jun 16, 2015 04:47 PM
