Speedo and Odometer dont work, Any suggestions?
Old 08-28-2010, 08:14 PM
Exiledbikr's Avatar
I bought a 1990 pickup with the 3vze a few months ago, and my speedo and odometer dont work at all, just the fuel and temp. How could i go about trouble shooting and fixing this problem?
Old 08-28-2010, 08:28 PM
myyota's Avatar
Check the speedometer cable, its probably broken.
Old 08-28-2010, 08:39 PM
Exiledbikr's Avatar
alright thanks, i was thinking that, wasent sure if it had a cable or was electronic. This is my first toyota.
Old 08-29-2010, 10:12 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
And just for future references, the Odo works off the speedo... It's all one unit, controlled by one source.
Old 08-29-2010, 10:32 AM
4Crawler's Avatar
Check the back of the transfer case, usually passenger side. There will either be a mechanical cable or an electronic VSS screwed in there. Transition from mech. to elect. was made some time in the early 90s models.
Old 08-29-2010, 10:35 AM
Birdbrain's Avatar
92 is when they switched to electrical in some models. His would be mechanical.
Old 08-29-2010, 11:04 AM
RiCh_90-yota's Avatar
remove the cluster might just be unplug
ashersullivan88yota
01-18-2022 05:37 PM
Colington
03-08-2020 09:51 AM
jerusry
10-19-2015 05:28 PM
Road Bull
10-10-2015 04:55 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Speedo and Odometer dont work, Any suggestions?
